I got one for you Senior's about a plug
Old Feb 22, 2003 | 04:44 AM
je3169's Avatar
I got one for ya if you pull out the head light switch there is a plug that is off to the right side of where the switch slides into the dash does anyone know what this plug if for ?I am thinking it is for the auto lights but i would like to know for sure. TIA
this is what I got
Old Feb 22, 2003 | 08:49 AM
SSCULLY's Avatar
je3169,
From a 2001 F-150 :
While I have never seen the plug that you are talikng about, the autolamp photocell is in the little grille area in the top of the dash by the windshield.
It is ~ 1" square in the oval part of the dash. Almost in direct line with the center defrost vent.
Good luck findout what that little plug is in the headlight switch, never seen that one before
Steve
Old Feb 22, 2003 | 07:11 PM
je3169's Avatar
thanks for the info SScully
Old Feb 22, 2003 | 07:23 PM
taterthedog's Avatar
plug
Not sure about that plug, I know that adjustable pedals are around that area. Also the switch for power sliding rear window is located next to the adjustable pedals if equipped. Is the plug you're talking about attached to the dash or just behind it somewhere.
Old Feb 22, 2003 | 07:26 PM
je3169's Avatar
the plug is behind the light switch in the hole where the light switch goes it is not pluged into anything just attached to the dash.Is there 3 plugs that go to the head light switch if you have auto lamps or just 2 ?
Old Feb 22, 2003 | 07:55 PM
SSCULLY's Avatar
je3169,
Do you have power pedals in the truck ?
If you don't this is probablly the connector for teh power pedal motor.
If you pull the oval off from around the radio, and the vents next to the radio, behind the dasjh, just below the drivers side vent there is a pin connector pushed onto the back of the dash also, I think this is the 4x4 selector.
If I am understanding this correctly this is the same thing ??
It kind of looks similar to the shape of a USB cable end ???
Steve
Old Feb 22, 2003 | 07:58 PM
je3169's Avatar
No i don't have power pedals would the switch for the power pedals be near the headlight switch? and is there only 2 plugs for the head light switch with auto lamps i know that the senser is over on the pass side of the dash i have the new head light switch and senser on order it is pre wired.
Old Feb 22, 2003 | 10:25 PM
The power pedal switch is located just below the headlight switch, do you know what color wires and how many are on this connector?
Old Feb 22, 2003 | 10:27 PM
je3169's Avatar
not off hand i am at work i can find out and post on sunday 1 think there are 4 but not sure.
Old Feb 22, 2003 | 11:13 PM
Lightbulb
Ok, just pulled the headlight switch out of my 02, sorry for not going out and doing this right away but it is -30 outside and it took awhile to get up the nerve to go out and look. I didn't see any other connector there on mine but it has power pedals. From what I could see the power pedal connector has 5 wires, red, black, white, and 2 green. This has 5 wires but probably only 4 terminals as I think the 2 greens go into one terminal. If this is the connector you have than it is probably for the pedals. My truck also has autolamps and there is still only 2 connectors on it. I hope this helps.
Old Feb 22, 2003 | 11:25 PM
Just looked at the wiring diagram for 02 and 03, and for the switch it says the connector should have 7 or 8 wires, the colors were a bit different than I said but it was dark out. Let me know what you have and I will have another look tommorow in the light.
Old Feb 22, 2003 | 11:29 PM
je3169's Avatar
thank for the help and yes that plug is for the pedals i just looked at a buddys that had pedals on it again thanks for the help
Old Feb 23, 2003 | 11:20 AM
no problem, glad I could help
