Remove headlight switch/locate parking light wire
Old Dec 29, 2002 | 02:14 PM
Steadymac's Avatar
Question Remove headlight switch/locate parking light wire
Can anyone help me locate the parking light wire (BRN) or tell me how to remove the headlight switch so I can trace the wire.
I found the moveable tab on the bottom of the headlight switch and it releases the bottom of the switch but I can not get it all the way out. Thanks
Old Dec 29, 2002 | 02:53 PM
Rockpick's Avatar
Moderator &
I have a feeling that this website: http://www.svtlightnings.com/svt/how...s/foglamps.htm will answer all of your questions...
That link is to the 'how to' on the foglight/parking light mod but, it shows wiring schematics and talks about removing the switch.
G' luck.
RP
Old Dec 29, 2002 | 04:01 PM
Steadymac's Avatar
Thanks RockPick. I have enough of the dash apart to see that there is not a metal clip holding it in on the bottom at least. I have a '99 Supercab, which I failed to mention before, and the switch looks different than the DK-labeled switch on the website you referenced . Mine is labeled BB and it is not a lot different but does not have the metal clip on the bottom.
I am close to being ready to do the fog lamp mod, though. The plastic 'rivets' are breaking off from the little pressure I am applying to get the switch out.
Old Dec 29, 2002 | 07:12 PM
Rockpick's Avatar
Moderator &
I've heard of numerous people having trouble with removing the switch and have even heard of folks actually breaking the faceplate in attempts to remove the switch. It's not an uncommon problem. Just be careful and, if you do break it,, go to your local junkyard and find another switch rather than buying a new one.
G'luck!
RP
Old Jan 9, 2003 | 06:23 PM
mrgrizleebear's Avatar
remove headlight switch
look at bottom of **** if there is a small hole try this disconnect battery turn switch to headlight on position insert small screw driver in hole to release **** and remove it turn **** 180 degrees and install back on switch rotate the **** counterclockwise to off position(1/3 of a turn m/l) rotate **** clockwise 1 full turn pull switch from panel installation is the reverse of removel this is from chilton 1997-00 man. 26666 chassis elec pg 6-25
Old Jan 9, 2003 | 08:41 PM
Robdude30's Avatar
Post
You should probably be able to find the parking light wire either in the drivers' kick panel or the bundle under the steering column. Go to www.the12volt.com and look in the wiring diagrams section for alarms/remote starters.
Old Jan 13, 2003 | 01:05 AM
Newbie54's Avatar
if you have the trailer harness under dash plug, there will be a brown wire in there for the parking lamp. You can't miss it because once the lower panel is removed, it will be to the left of the OBD plug with nothing attached to it.
