Hey Mike
Old Jun 4, 2002 | 03:25 PM
skinny's Avatar
Hey Mike
I posted this in the engine forum, but I thought you might know. I did the turn key on while holding odometer button and it showed a code of d262. Mustang World showed it to mean Missing SCP Message. Do you have any idea what that is? Thanks in advance.
Old Jun 4, 2002 | 04:02 PM
JMC's Avatar
JMC
25 Year Member
Skinny,
PINPOINT TEST H: NO MODULE/NETWORK COMMUNICATION — SCP COMMUNICATION NETWORK
² H1: CHECK SCAN TOOL PIN 2 AND PIN 10 FOR DAMAGE
² H2: CHECK DLC 209 PIN 2 AND PIN 10 FOR DAMAGE
² H3: CHECK CIRCUITS 914 (TN/OG) AND 915 (PK/LB) FOR OPEN
² H4: CHECK CIRCUITS 914 (TN/OG) AND 915 (PK/LB) FOR SHORT TO GROUND AND POWER WITH THE PCM C174 DISCONNECTED
² H5: CHECK CIRCUITS 914 (TN/OG) AND 915 (PK/LB) FOR SHORT TO GROUND AND POWER WITH THE NGVM C197 DISCONNECTED
² H6: CHECK CIRCUITS 914 (TN/OG) AND 915 (PK/LB) FOR SHORT TO GROUND AND POWER WITH IN-LINE C158 DISCONNECTED
² H7: CHECK CIRCUITS 914 (TN/OG) AND 915 (PK/LB) FOR SHORT TO GROUND AND POWER WITH THE INSTRUMENT CLUSTER C237 DISCONNECTED
Have you removed the cluster lately?
JMC
Old Jun 4, 2002 | 04:19 PM
skinny's Avatar
No, the truck is a 2002 PSD. The only thing I have done is disconnect the batteries. Could this have done this and if so is it something I need to get checked.
Old Jun 4, 2002 | 05:43 PM
JMC's Avatar
JMC
25 Year Member
Skinny,
The info I posted was for an F-150. I will check for the PSD.
Regards
Jean Marc Chartier
Old Jun 4, 2002 | 06:01 PM
skinny's Avatar
Thanks. If you have a chance, could you tell me what d027 is also.
Old Jun 6, 2002 | 06:56 PM
Former Sponsor
Hi Skinney,
I have to apologize, as we are a performance company, not a repair shop, so we don't diagnose vehicle problems that have nothing to do with the performance of the powertrain itself. Powertrain DTC's in these OBD-II's will always have the P prefix, and those are the only codes that we can help you with.
JMC has very kindly provided a lot of infomation in his response to you, as he has always done for years around here (thanks JMC!). What you are getting *may* be related to the disconecting of both batteries in the PSD, but I can tell you that this is not something that commonly happens when we disconnect the batteries on a PSD, so it sounds like something else may be going on here.
Don't hesitate to have your dealer check this out for you, you've got a brand new vehicle under warranty there.
Sorry I couldn't be more help to you directly, & good luck!
