Need stock tune for 5.4L
Old Feb 21, 2013 | 07:14 AM
kjohnson1's Avatar
Long story short: I need a stock tune (honestly I'll take any working tune) for an STC Excalibrator 2 (X2) for my 2004 FX4 5.4L. Hex key: RXAQ5B4.
Any help would be greatly appreciated and consideration will be given.
Thanks,
-kevin
bronco_5@hotmail.com
214-663-8601
Old Feb 21, 2013 | 03:08 PM
openclasspro#11's Avatar
Dealer,who in their right mind would give u their stock tune ,unless they were trading it in.
Old Feb 21, 2013 | 04:05 PM
kjohnson1's Avatar
Pardon my ignorance. Why wouldn't they? I'm not into pulling shenanigans.
Old Feb 21, 2013 | 04:32 PM
At this point you're probably stuck going to the dealer.....imo
Old Feb 21, 2013 | 05:44 PM
More background on this would get you much better replies.
Old Feb 21, 2013 | 10:32 PM
Veteran: Army
in for the rest of the story...
Old Feb 21, 2013 | 11:51 PM
kjohnson1's Avatar
An acquaintance gave me the x2 to 'play with'. I knew better given my background in software, but I connected it to the DLC anyway. I reasoned that if it were incompatable, the x2 would inform the user.
It didn't. The x2 attempted to load new paramaters and failed. I disconnected the unit and started the truck. Result: rough idle and no throttle. Next I attempted to return to the stock tune. Result: Same as above.
Codes P2104 and P2111. Tested the resistance on the throttle body actuator and passed. I have not tested the TPS yet.
From the research I've performed, all signs point to a failed PCM or a tow to the dealership and associated *** whooping charges.
I thought if I could get a tune for the truck then I could attempt to load it and test. If the PCM were still good then I could have it re-flashed and lesson learned.
Old Feb 22, 2013 | 12:04 AM
Get it to the dealer....and don't "play" with programmers unless you fully understand....imo
Old Feb 22, 2013 | 03:28 AM
kjohnson1's Avatar
yeah, because you've never made a poor decision. There's always one.
Next up: The Referee.
Old Feb 22, 2013 | 12:14 PM
We've all made poor decisions and you aren't getting bagged for that - but the result in this case pretty much requires a visit to a Ford dealer. I doubt you blew the PCM, but it definitely needs to be reprogrammed with the proper equipment.
A reflash shouldn't be more than 1 hour book labor.
Old Feb 22, 2013 | 12:33 PM
I'm not flaming ya.....it just made me a little concerned with your use of the word "play"
Hopefully ya get her running again...
Old Feb 23, 2013 | 11:16 AM
Veteran: Army
let us know how much the re-flash costs along with the tow
Old Feb 24, 2013 | 11:55 AM
kjohnson1's Avatar
i'll keep you all updated. Thanks for the encouragement that the PCM is not fried.
I know the VIN is needed to reprogram the PCM. Does anyone know if the vehicle is needed? I have received conflicting information that the truck needs to be present vs removing the PCM from the truck and taking it to the dealership.
Old Feb 24, 2013 | 09:27 PM
Veteran: Army
most likely due to the PATS, the truck needs to be at the dealer for the total re-flash
Old Feb 24, 2013 | 10:56 PM
had to take my 03 to the ford dealer to get reprogramed after my edge took a crap on me.. Ford only charged me 65 dollars.. The tow was more expensive then the reprogram.
Shouldnt be a problem at all. Just get the truck there
