SCT tuner Unlock ECM Failed
i bought a SCT handheld tuner with custom tunes for my 1998 4.6 swapped to a 2004 5.4. Retained the 1998 ECM, tuner has all the details about the swap.
Try to program the ECM and get the Unlock ECM Failed error 1019. Contacted the tuner several times, did some trouble shooting and he had me talk to SCT tech. Spoke to 3 different techs, first remotely reformatted the device, second had me check for 18 volts during attempted programming on pin 13 which I had, 3rd tech loaded an older version of firmware none helped so they gave me a RMA number to return the device to check it.
Well today Not confident the device was bad I decided to remove the ECM to take a look at it before I sent back the SCT tomorrow. ECM looked stock and unmolested, I looked under the plate on the back and there was a chip, it says Hyperchip.inc. FL1C28. 10/26/98 I'm guessing this is my problem, what is the fix? New ECM? New stock chip?
I have an email out to the programmer but it is Sunday and wonder what you guys think.
Mike
Mike
Mike
Mike
I think you are trying to load a program on top of something that is not stock, and that's why things don't work.
- Jack
