CTS install??
The "big wire" you're talking about is the one that goes from the OBDII port to the back of the programmer? Which end looks like it won't fit? No one has ever commented on this problem before, so I wonder if possibly they sent you a cable meant for a diesel application?
I think you need to call Edge tech support. I'm sure if it's the wrong cable, they'll get you the proper one quickly.
- Jack
- Jack
Oh sorry! I wasn't specific enough. The wire fits the obdII. Most toddlers could figure that out haha. I mean running the wire up the side panel and setting up the dash pod. The wire doesnt look like it will fit running up the side panel of the dash and in between the door.
I ran my Garmin cable up under the knee bolster, (as in behind it), and through the side panel, and immediately tucked into the door rubber. I found that trying to go around the knee bolster was simply too far. I suspect you will have the same success with the edge cable routing.
- Jack
Yeah I got it figured out! Thanks! But I could NOT get the back up camera to show a picture. I ran the ground to the battery. and I saw something on the internet about something like that happening when the ground and the power source being to far apart? Has anybody ran into this problem before??
It's hard to test for video feed, but it's pretty easy to test for camera power if you have a simple multimeter. Just see if you have battery voltage at the camera end of the power cord when you're in reverse (or when the key is on, depending on how you've wired it). The original camera was wired to be always ON whenever the ignition was on, so you could select it while moving forward. You could also take the positive power feed from the backup light wire to just have the camera while backing.
Provided you connected the power feeds properly, I don't see them being a problem, but the video feed is "touchy". If you can test with a known, good, possibly shorter RCA type cable, it will tell you a lot. It's what I did.
- Jack
