tuner destroying trany?
Old Aug 15, 2011 | 05:57 PM
digbyz's Avatar
Is it probable that my sct x3 by vmp is destroying my trany? Ever since I got a new tune from him my truck has hummed in the lower rpms.
Old Aug 15, 2011 | 06:12 PM
JackandJanet's Avatar
A hum by itself doesn't mean anything. Do you have any other mods, like a CAI?
- Jack
Old Aug 15, 2011 | 06:36 PM
Veteran: Army
did you firm up the shifts???
Old Aug 15, 2011 | 11:07 PM
digbyz's Avatar
I don't have q Cai. But I have cat back exhaust, its coming from the trany or front end. I did firm them up in the past. But took it back down.
Old Aug 16, 2011 | 02:24 AM
camopaint0707's Avatar
Would firming the shift points hurt the trans? I'd like to know too.
Old Aug 16, 2011 | 03:18 AM
LincolnMarkLT20's Avatar
I raised my shift points and had no problems, it's been a year now runs great no problem with trany.
Old Aug 16, 2011 | 08:46 AM
dsq3973's Avatar
Firmer shifts=less clutch slip and that is a good thing because to much slip and you burn the clutches up if you adding more power. But to add to that to hard of a shift and there is no give when everything locks up and you will start damaging parts.
Old Aug 16, 2011 | 08:51 AM
There's a balance......and every truck out there is different as to how it will effect it.....
Old Aug 16, 2011 | 08:08 PM
digbyz's Avatar
I don't think the firmness worked anyway
Old Aug 16, 2011 | 09:41 PM
Veteran: Army
using a tuning device to firm up the shifts you stress the pump
Old Aug 16, 2011 | 09:51 PM
Smokewagun's Avatar
Curious why all these custom tune shops recommend firm shifts?
Old Aug 16, 2011 | 11:17 PM
digbyz's Avatar
So could it make it hum
Old Aug 17, 2011 | 01:33 PM
Less slippage = less clutch wear = lower fluid temps.
Old Aug 22, 2011 | 10:25 AM
Leadsled124's Avatar
This. OEMs soften the shifts to make it smoother to make everyone happy. So when ur grandma is in the truck shes not complaining how rough it is. Just like all the other little crap they do to kill the party uight not even realize. Like that little waffle cast design insider stock intake box is actually designed to quite the intake rush noise we all like
But a little tranny whine is usually fine unless it's way more apparent than before. Is it actually a trans whine or is it more of a buzzing like a fuel pump just delivering more fuel?
Old Aug 22, 2011 | 04:33 PM
digbyz's Avatar
No its a mechanical wine at low rpms sounds like a bad belt in a tire. I don't think it would be the fuel pump? It does make weird noises when im downloading a tune tho???
