Which canned tune to run?
Old Aug 11, 2011 | 12:15 PM
ranger332's Avatar
I will be recieving my Gryphon shortly and will be waiting for my custom tune until PHP has written it. I've come to understand that my take a while, which is fine with me. I'm sure its worth waiting for. Which canned tune should I run in the meantime? I belive PHP reccomends running the 87 tow tune until I recieve the custom tune. Is that the best tune to run while waiting? I guess it would be since I'm using 87 octane fuel, even though I'm no towing anything. Right? Just looking for a little advice and input on the matter.
Old Aug 11, 2011 | 12:30 PM
shotgunz's Avatar
Don't you have an after-market intake? If so, then yes, use the canned tow tune.
If you haven't modified the intake system, then the canned 87 performance tune should also be fine.
Old Aug 11, 2011 | 12:54 PM
ranger332's Avatar
Yes I do have an intake so in that case the 87 tow is reccomended because it runs a little richer, right?
Old Aug 11, 2011 | 01:11 PM
shotgunz's Avatar
You are correct, sir.
Old Aug 11, 2011 | 01:36 PM
Ethan21's Avatar
I have the gryphon cs and have been running the tow tune while I'm waiting. And it helps it out alottt. Gas and power
Old Aug 11, 2011 | 02:11 PM
If you haven't modified the intake system, then the canned 93 performance tune should also be fine.
Fixed it for you!
Old Aug 11, 2011 | 02:21 PM
shotgunz's Avatar
Thanks 88!
I thought the "new" CS/CTS canned tunes were 87 performance, 87 tow, and 91+ performance.
After reading your fix, I guess they are tranny only, 87 tow, and 91+ performance (like the old Edge Evolution canned tunes).
My bad, ranger - please listen to 88.
