check fuel cap warning?
Old Aug 3, 2011 | 08:32 PM
imurhero11's Avatar
I reciently replaced my stock gas cap with an after market one that has a key.due to the hih price of gas lol. The check engine light and " CHECK FUEL CAP" message scrolls on my screen. Any insight would be appreciated.
Old Aug 3, 2011 | 09:22 PM
JackandJanet's Avatar
It's not sealing properly, and this is an emissions concern. If you have to have your truck emissions inspected, it will fail. If that is not required where you live, you can ignore it. (But of course you ARE allowing hydrocarbons to escape into the atmosphere.)
Really, I'd try to find a locking cap that does not throw this code. I don't know honestly if it's important in fact, but the truck was designed as a "system", and if any component in that system is not working properly, there MAY be bad side effects on the rest of the "system".
And, I'd hate to be seeing this message anytime I was driving my truck.
- Jack
Old Aug 3, 2011 | 10:24 PM
jgger's Avatar
The cap is either defective or the wrong one for your truck. Take it back and exchange it.
I've had a locking cap on my 03 for years with out any issues.
Old Aug 3, 2011 | 10:33 PM
imurhero11's Avatar
cool thanks guys appreciate it. i actually swaped the rubber seal gromet from the oe cap to the new one and it turned off!
Old Aug 4, 2011 | 11:03 PM
tbear853's Avatar
Lightbulb
Originally Posted by imurhero11
I recently replaced my stock gas cap with an after market one that has a key.due to the hih price of gas lol. The check engine light and " CHECK FUEL CAP" message scrolls on my screen. Any insight would be appreciated.
That happened to me just this April as well.
I tried the cap several times. Noticed a whiff of gas smell too. Never did get the cap on tight enough to make warning go away ...
... but the warning did go away later that day
after I removed and repaired and reinstalled the small high pressure fuel line and larger vapor return lines from above the fuel tank where them DAMN SQUIRRELS HAD LUNCH!
... $286 at Ford and no warranty against teeth so .... I used splices to repair mine and used some copper as well. If it happens again, I have a coil of copper and the needed adapter fittings to replace from tank outlet to filter where they no longer have a fuel tank to sit on top of while MUNCHING DOWN ON PLASTIC!
Damn squirrels! We feed them enough corn and they steal bird feed out of those feeders ..... leave my TRUCKS and CARS ALONE!
Old Aug 5, 2011 | 01:37 PM
imurhero11's Avatar
thats is unbelievable! haha wow man well good luck with the critters
lol
Old Aug 13, 2011 | 01:10 PM
craneman's Avatar
I got one too when i park at remote trail heads mine is from Motorcraft no problems at all
Old Aug 13, 2011 | 02:04 PM
Marshall Robert - I moved your posts and replies to a new thread in the 97-03 Forum: https://www.f150online.com/forums/19...l-economy.html
And, to those of you whose posts I moved by mistake, hope I've got it right now. :o (Thanks, glc!)
- Jack
Last edited by JackandJanet; Aug 13, 2011 at 07:59 PM. Reason: Restored some posts.
