SCT X3 will not datalog on livewire??
So I am having trouble getting my new x3 to datalog in real time with livewire. I have updated my x3 and livewire both to the most current versions. When I plug my x3 into my laptop and open livewire, the x3 will connect to it and the livewire will check the PID's and find them all. But when I start datalogging it won't show up on livewire, everything just reads 0.0000 etc.. even though the information IS being logged on the x3.. any ideas?
Well that didn't work. I can't figure it out... when I connect the x3 to my laptop the sreen says livelink activated, scp activated or whatever.. Then livelink checks the PIDs and shows them all, so I know it is connecting with the x3, but when it shows the graph and gauges everything reads 0.0000...... do i need to enter a code or equation or anything?? When I asked Justin @ VMP he said I didn't need to because the new livelink does it for you.. ? I am stumped.. everything is up to date, firmware, drivers, software etc...
Ok,so i got it working- I had the wrong module enabled. I had it on ecm #1.. buut I still have some wierd things going on. When I am datalogging with livewire all my gauges go crazy. The tach and speedo go all over and my cel and oil light turn on and off.. Is that normal? Once I stop the datalog is goes back to normal..
JR- thanks for the advice. I think I talked to you today on the phone as well. So I tried logging 11 parameters and it still wouldn't log all- only six. This is why I don't get it- I can datalog with just my X3 and log all 23 allowable parameters and it works fine. But when I try to log with livelink only five or six.. ? The problem is that the limited parameters available with only the X3 are not all the ones I need. Why can my PCM keep up with the X3 with 20+ parameters but when I use livelink only 5 or 6??
UPDATE- So today I was at my wits end so I decided to uninstall livelink-again. Then I returned my truck to stock and re-updated my X3 even though it was up to date. So something worked because I logged nearly all the parameters I needed! The only ones that would not work were iac trim 0 and iac trim 2. I even tried logging them solo without any other items being logged- still didn't work so I sent off what I had to Justin and we'll see what he says..
