edge code f2
Old Mar 12, 2011 | 04:16 PM
tincan81's Avatar
edge code f2
I was trying to return my 99 f150 to stock so I could smog it and got this code does any body know what i means?? It also says that splash.lcd was not located. Any help would be really apriciated
Old Mar 12, 2011 | 04:32 PM
Changing back to stock for an inspection? I never do and it passes the inspection scan every time.
I hear the 97-03 edge cables are prone to failure. Maybe this is going on.
Old Mar 13, 2011 | 02:06 PM
JackandJanet's Avatar
DO NOT put your truck back to stock before a smog inspection. If you do, it almost guarantees you will fail the test due to a P1000 code that will be set. Just leave it tuned and remove the programmer and cable.
Please read the "sticky" at the top of this forum. It covers when you should return to stock.
- Jack
