Original Edge vs. Edge CS
Old Jan 19, 2011 | 08:30 PM
kitchenboy's Avatar
Just wondering what are the biggest advantages of the CS over the original Edge programmer. I have the original, thatI was planning to send to PHP to convert to a Gryphon, and was wondering if the CS is a better idea. I know that converting mine is definitley the cheaper route. Just wondering?
Old Jan 20, 2011 | 02:27 AM
Veteran: Army
since you're getting a custom tune I wouldn't worry about it
Old Jan 20, 2011 | 06:37 AM
shotgunz's Avatar
Yep. In fact the Evo has features that haven't been 'implemented' in the new CS/CTS platform.
Old Jan 20, 2011 | 10:43 AM
Keep your original edge evolution and get it converted to a Gryphon.......
With the CS, edge took away some end user adjustments that are supposed to be reimplimented but as of yet are not......
Old Jan 20, 2011 | 11:22 AM
JackandJanet's Avatar
Ditto - the custom tunes are the same in either unit.
The CS offers more "bling" than the monochrome Gryphon and should be more reliable if used in the pre-04 trucks due to problems with the OBD cables in those units. The CS could have its tunes "upgraded" though for an 09+ truck if you decided to trade up. The monochrome evolution can't be used beyond the 08 model year.
- Jack
Old Jan 20, 2011 | 11:45 AM
Glen R's Avatar
I have another question along these lines. Edge is showing Fusion, and now Lightning software to use for updating the EVo. Which one should I be using, I currently have Fusion.
Old Jan 20, 2011 | 12:17 PM
Glen, this is confusing, to say the least: Here's what it says on Edge's website about Lightning:
*This software only works on
EEF2100 versions E4.XX.XX
This is found on the silver
serial sticker on bottom of
product.
EEF2400 – Ford F-150 2004-2007
EEF2400 versions E3.XX.XX
product.
Now, Lightning actually existed BEFORE Fusion, and Fusion was supposed to be a multi-application program. So, I'd say if Fusion works with your unit, stay with it.
- Jack
Old Jan 20, 2011 | 12:23 PM
Glen R's Avatar
product.
product.
- Jack
That is kind of what I was thinking. I figure I will use it until it stops working then try Lightning. By the way I have sent two emails to Egde requesting clarification, with no response.
