What rpm are you shifting at 04-08's
Your camshaft and heads are the primary dictators of the power band. No tune is going to move your peak horsepower rpm much over stock. At 5,500 and 5,750 you're just stressing the engine and transmission. 5,250 rpm is probably as high as you would want to see on a stock engine. I presume you're discussing the 5.4.
Yes the 5.4...and I should have said that I plan to drop in the frpp hot rod cam mainly for sound...but if it's still making power at 5k...I wanted to know what could I safely go to if the power was still climbing.
And for conversation sake...if the motor was built and had pnp heads too...what can a stock fx4 trans take rpm wise?
The dyno should also also pinpoint your peak rpm. If your power band moves up a few hundred rpm you might want to replace the torque converter anyway with a good aftermarket unit with a higher stall.
I'm sure the tranny will need some help sooner rather than later with 140k on it...I'm trying to let it ride like it is for now.
If the stock injectors run out up top do y'all know if 2006 mustang gt stock injectors would fit/work? I have some from when I put my whipple on it.
