Really?? Reflashed PCM.
Old Nov 26, 2010 | 06:31 PM
Altatruck's Avatar
Well of course, in true Ford style they have reflashed my PCM to some other HEX code. I put in the form to get my tunes redone.
Just wondering what the turnaround time on that is? I hope to god its not the same terrible wait time as it is to get them in the first place.
This truck blows goats on the stock tune. Gutless with a sloppy transmission. Kind of takes the joy right out of driving.
Old Nov 26, 2010 | 07:05 PM
Altatruck's Avatar
Another note, is it possible to re-download canned tunes and run them in the meantime?
Old Nov 26, 2010 | 07:43 PM
MGDfan's Avatar
Hey bud.
I believe so - you'd be returning yer unit to it's original factory 'canned' condition.
Sorry to hear they did that.
How's the truck running otherwise?
At least yer coming out of the deep-freeze - it's heading this way, eh!
MGD
Old Nov 26, 2010 | 07:57 PM
Altatruck's Avatar
Running way smoother for sure. Should be all fixed up.
I'm sorry to hear that. Life sucks in a deep freeze.
Thanks for the reply. I'm going to try loading up the canned tunes however you do that. I just can't do the stock thing, been jaded by the custom tunes.
Old Nov 26, 2010 | 08:32 PM
The canned tunes will work if they recognize the new HEX code.
Old Nov 27, 2010 | 04:30 AM
Altatruck's Avatar
The canned tunes typically work for all hex codes I thought. That is why you can order the tuner not knowing the hex code, right? Or are you implying that it could be a new hex code ford has come out with which won't be compatible with the canned tunes because it wasn't in existence at the time the canned tunes were developed?
Old Nov 27, 2010 | 07:20 AM
MGDfan's Avatar
Yep.
For how ( from Bill on PHP's forum):
"All you need to do is connect to Pegasus, go to [Updates], and select [Gryphon Update Manager]. On the update screen, select the latest firmware and calibration versions and then click the [Update All] button. This will load the latest canned version of the firmware and calibrations. Of course, make sure that the programmer is returned to stock or the unit will not update."
As long as those latest canned versions have been regularly updated - you should be good to go.
You'll know right away.
BTW - you never posted what the fix was. Share!
MGD
Old Nov 27, 2010 | 10:50 AM
Yes, that is what I am saying. If the canned tune has been updated to include the latest HEX, you will be good to go. If the HEX is not incliuded in the list in the tuner, you won't.
Old Nov 27, 2010 | 11:11 AM
JackandJanet's Avatar
And, before you revert to canned tunes, you ARE sure they reflashed your PCM, right? You DO have a new "hex" code now?
MDG gave you the correct procedure for the monochrome Gryphon. (Maybe I should take a vacation and let him handle things.) But, if you have the CS or CTS units, you connect the programmer to the PC with Fusion running, and it will automatically convert the custom tunes to canned tunes without you having to do anything other than sit there and "watch".
- Jack
