Edge Evo, Gryphon CS, or SCT?
Well - ideally, an external wideband is best. Lacking that, there may be a way to use the narrowband O2 voltages, for stock trucks. That would be up to Bill, though. You'd also need fuel trims, load, MAF counts, spark advance, RPM, throttle position, IAT, CHT, and a couple / few other DMR/PID's. Again - it's Bill's call. Each tuner has their own method of going about this.
good luck
MGD
good luck
MGD
I want the truck running perfect to start before I datalog
yall just confused the hell outta me...thats why i dont dare try and tune my truck. ill leave it to the experts lmao. is the only benefit of having the programmer in the truck is actually swapping tunes on the fly?
- Jack
On a gas engine, the only benefit of having the programmer in the truck is if it has gauges, such as the Edge and Gryphon and Livewire. If no gauges, program the PCM and put the hardware where you want to store it. Takes 5 minutes.
what exactly is a "evo converted by PHP"? im looking into purchasing one from the BST and just curious what that means. Is the EVO capable of custom tunes like the Gryphon CS? Also other question is do i need a custom tune with the DWV intake mod?
A Gryphon is a rebadged, lobotomized canned Edge product, done exclusively by PHP.
Initially preloaded with ehanced canned tunes by Bill, and updateable to full custom tuning upon payment + wait time.
Do some reading on PHP's site for full details, pricing, etc: www.gopowerhungry.com
MGD
Simple.
MGD
MGD
MGD
Simple.
MGD
MGD
This does not pertain to the CS+CTS programmers....this is only for the edge evolution upgraded to a monochrome Gryphon.
thank you. im gonna get the monochrome and do the DWV mod since i dont need a custom tune for it right away and its much cheaper then a CAI and yields the same results minues the drone
thank you
Programmers can clear codes BUT if the issue that's causing the code IS NOT FIXED then the code will come back.
You'll need to figure it out and get it fixed.....
One example of a code the programmer cannot clear is a p1000......this one needs to be drive cycled till its gone.
