Cross Eyed!!
Old Oct 12, 2010 | 09:32 PM
tbear853's Avatar
Originally Posted by Reel_Drifter
tarajerame,
So if i dont put a programmer, re gear, and super charger in my truck im going to run "thru transmissions and fuel like they are going out of style?" Gas I believe but "transmissions" gimme a BREAK!
Anyways thanks to the rest of you guys! I will be purchasing a programmer soon, hopefully a Gryphon. Thanks Again!
If you drive real easy like, avoid full throttle usually, don't tow .... you'll be OK .... but when you put those heavier and taller tires on, you effectively gave up torque multiplication due to the taller tire .... and you added weight way out at the tread that has tio be "spun up" to speed and which has to be slowed down as well.
You added work for the transmission .... and for the brakes. Tuner will help, and with just 35s if you have 3.73s gears likely OK.
Nothing much gonna help them brakes.
Old Oct 14, 2010 | 03:19 PM
Reel_Drifter's Avatar
Yup running 3:73 gears. And no I dont fear the re gear...HAHA...I fear my wallet. In college and work part time so re gearing is out of the question at the moment.
Old Oct 15, 2010 | 10:13 PM
tbear853's Avatar
3.73s and 35s, you'll be perfectly OK!
Old Oct 16, 2010 | 03:29 AM
Veteran: Army
as long as you don't care about power or mileage
Old Oct 17, 2010 | 01:39 PM
Engineering degree coming real soon...$ should'nt be much of an issue then. Until then going to run a edge programmer. Thanks to All....
