Best Chip for fuel efficiency
Old Aug 14, 2010 | 09:37 AM
  #31
Norm's Avatar
Originally Posted by 99rckstrexpy
a freind of mine has a 97 1500 z71 with the 5.7 vortech and he programmed it with the hypertech max energy programmer and he went from going a little more than 80 miles off 7 and a half gallons of gas to going about 120 miles. as long as he kept his foot out of it it helped on gas mileage alot.
those numbers arent exact. of course it would go more than 80 miles before its not like i ran it completely outta gas and it always wouldnt go 120 but it would go around those numbers. and 50% or not it was only like 5 mpg it increased.
Old Aug 14, 2010 | 09:49 AM
  #32
shotgunz's Avatar
hehe....
I threw the
after post #15.
Old Aug 14, 2010 | 11:27 AM
  #33
DigitalMarket's Avatar
The mileage gains on a 5.4 Super Duty are going to be minimal due to its weight. The 6.8L V10 does much better... the 5.4 is simply not enough engine for that truck. There's only so much that can be done via timing and fuel on 87 octane to gain some mileage. The bulk of mileage increases will be due to transmission torque converter lockup strategy changes, and then only if the programmer makes those changes with mileage in mind, and if your driving habits are suited for it. For instance, if you do mainly highway speeds you won't see much gain because even the stock tune is going keep the converter locked at those speeds. If you do a lot of 35-50 mph intermittent driving then you may see a gain from a more aggressive lockup schedule, but don't expect miracles.
Old Aug 14, 2010 | 11:28 AM
  #34
Originally Posted by shotgunz
hehe....
I threw the
after post #15.
Ke$ha's song blah blah blah rings a tune here also.........
Old Aug 15, 2010 | 07:43 AM
  #35
openclasspro#11's Avatar
A chip won't work, you have to have a handheld tuner. You need to read the stickies.
u can chip a 99 btw, lose the lift and give the 250 some of the little aerodynamics it had back
