2010 f150 and sct tuner - transmission jumps
Old Feb 3, 2011 | 09:17 PM
  #31
Red'10FX2's Avatar
SCT from VMP on a 2010 4.6... no problems, no error codes, "common" or otherwise.
Old Feb 4, 2011 | 12:57 PM
  #32
2009KR's Avatar
Originally Posted by johnjohnson78
Just curious if the new tunes have kept the P0605 code from coming back?
My edge programmer threw a couple of these and then my dealer claimed the PCM was corrupted and needed to be reformatted (a couple hundred bucks later) and I'm not going to reprogram my 2010 until I know that this issue is solved. I realize you're running an SCT tune which is different BTW
If I remember correctly, P0605 is just the code that is thrown (without lighting the light) when the ECM is reprogrammed. It clears it self in a little while (3 warm-up cycles maybe?). It is used for emissions testing. I don't think any tune can avoid causing this code.
Old Feb 4, 2011 | 03:16 PM
  #33
redtherocket's Avatar
I can't believe how many times this guy had to get tunes.....Have them fixed...screwin' around..
Wow.
I went to Steeda for a SCT X3 programmer.
The tuner went out and plugged it into my truck, went back inside and loaded it with tunes.
He inhanced the shifting(which is perfect) and gave me a 87, 91, 94 tunes...
I had no issues...codes....Nothing...
Old Feb 28, 2011 | 03:06 PM
  #34
slim10fx2's Avatar
I haven't had any more issues. Actually I had to start driving a little further to work so I switch over to the fuel economy tune to save gas and it works great too.
