XCal 2 - Flash Proccess?
Old May 18, 2010 | 01:18 PM
Haemon's Avatar
Well I seem to get the jest of the flashing process down, im not new to flashing over things (I'm a computer geek :P... flashed many a BIOS before, same exact concept)...... Only I recall being told that with my year of truck (1997) that there is one other VITAL step involving pulling a plug or fuse, that failing to do so could result in a corrupt flash. Anyone have some insight on this, which fuse and why?
Old May 18, 2010 | 01:42 PM
shotgunz's Avatar
IIRC it's the fuel pump relay or module.
It's not in your SCT manual?
Edit:
Found it! http://www.sctflash.com/PDF/XCal2Manual.pdf
Program Vehicle Menu:
First disconnect the fuel pump and electric fan fuses.
Last edited by shotgunz; May 18, 2010 at 01:44 PM. Reason: http://www.sctflash.com/PDF/XCal2Manual.pdf
Old May 18, 2010 | 02:19 PM
Haemon's Avatar
Thanks Shotgunz, I noticed that but I recall being told that with the 97' and some 98's that there was someone else or specific that had to be done as a precaution to make sure the battery didn't drain itself during the flash process that didn't have to be done on the newer trucks... hmmmm
Old May 18, 2010 | 02:23 PM
shotgunz's Avatar
You can easily eliminate any potential (of low voltage) by using a small battery tender (low output charger) during the process.
Here's the other thread...
https://www.f150online.com/forums/ch...g-xcal-ii.html
And another:
https://www.f150online.com/forums/ch...use-flash.html
And another:
https://www.f150online.com/forums/ch...elp-xcal2.html
