egde programmer
Old May 12, 2010 | 11:36 PM
aaron150's Avatar
egde programmer
ok ive had my edge for about 6000 miles. i love it, except for one thing. at highway speed if you pull out to pass and give it gas, about 3/4 throttle, it will go from 4locked to 2nd gear. it slams hard and i was wondering if there was a way to fix this?
im sure this isnt right or good on things. it didnt do it before the tuner.
im running level 2 tow, and the gears and tires are the only things changed.
thanks
aaron
Old May 13, 2010 | 01:21 AM
Ftruck09's Avatar
Do you have a manual? You could do alot of things. Adjust the shift firmness, the shift points.......
Old May 13, 2010 | 03:10 AM
Veteran: Army
thanks
aaron
what size gears and what size tires???
Old May 13, 2010 | 02:47 PM
JackandJanet's Avatar
And, when you say "highway speed", what do you mean? 60? 70? 75?
What you're experiencing is a WOT shift, and, I suspect you are actually opening the throttle to 90% or more. Once you are at "WOT", the transmission gearing is dependent on engine RPM. You could lower your 3-2 downshift value I think, to keep it in 3rd to a lower RPM. You'd also want to lower the 2-3 upshift value too.
The thing is, the canned tunes and most custom tunes are going to keep you in a particular gear at WOT until the engine reaches around 5000 RPM, since power and torque are generally increasing below that point. So, I suspect at your "highway speed", the speed/RPM value for 3rd gear is still below the upshift/downshift point and it drops you into 2nd. I know this happens to me, and I just let it happen since I usually want to get around someone fast on a 2-lane road.
- Jack
Old May 13, 2010 | 11:30 PM
aaron150's Avatar
it has 3.55 gears and 275/65R18 tires. and at highway speeds i ment 60. and at that speeds its only at 1600-1700rpms. im just worried about it tearin up the trans!! dont want to have to replace that yet.
thanks
aaron
