running lean pt.2
well im back again (part 1 https://www.f150online.com/forums/ch...ning-lean.html) and i did a few of the suggestions. i cleaned the maf and iac, both were pretty clean so i felt the throttle body was ok. i check for vac leaks and replaced a cracked tub that i had taped a while ago. so after doing all this i unplugged the battery(10min) to reset the pcm. then i set the edge to level 2 and took it for a spin. same result, pinging/rattling in lower rpms and now noticeing in the higher rpms. it pretty much does it all the time now on level 2 when its under stress. so what should i do? im also going to key west in two weeks and will be towing a 19ft boat so id like to get this resolved. also can i tow on level 1 or just return to stock(level 0)?
thanks and sorry for all that reading
thanks
thanks
also forgot to add that when i first got the edge i ran it on level 2 all the time, then this rattle started to develop slowly over time.
thanks
well, i tried the -2 timing and that did seem to help. it doesn't rattle as much and was a lot less noticeable. so should i push it even farther to -2.5 or -3?
thanks
thanks
no, just the "Gotts mod" and the edge are the only mods.
forgot, i also tried the 93oct on level two and it did go away.
so i called edge today and explained my problem to them. they set my edge back the the original tune before i updated it(like when it used to work right). after trying it out and its still not working right. this is becoming a real PITA
. when i called them they offered no real solutions and basically said i should just run 89oct and thats not a good solution in my book.
anyone else
. when i called them they offered no real solutions and basically said i should just run 89oct and thats not a good solution in my book.anyone else
