running lean
Old Apr 6, 2010 | 09:52 AM
F150man21's Avatar
running lean
i have a 2000 5.4(93k), edge evolution, and have done the "gotts mod". when i set my edge to level 2 and the motor goes down in rpms(1100-1500) it makes a knocking or rattling sound like spark knock or octane knock. on level 1 its fine but just even less fun to drive so is it the gotts mod causing this or is there another solution?
Old Apr 6, 2010 | 09:55 AM
It should not be the Gott's mod. I would clean the MAF, the IAC and the throttle body.
Old Apr 6, 2010 | 11:50 PM
karnak's Avatar
Registered User
i dont think it would be the gotts mod because i have the evolution and the gotts and i have not had any problems like that... have you customized any of the tunes ? whenever i mess the the WOT or shiftpoints it acts funny sometimes
hope that helped
Old Apr 7, 2010 | 08:23 AM
F150man21's Avatar
hope that helped
the only thing i customized was the tire size. also when i did change other thing like rpm limiter the truck would blow black smoke like a diesel and run like crap. tomorrow i'l take bluejays advice and clean the MAF, the IAC and the throttle body.
anyone else with any suggestions?
Old Apr 7, 2010 | 10:46 AM
Use high octane fuel when you use Level 2.
Old Apr 7, 2010 | 10:48 AM
shotgunz's Avatar
I thought level 2 was 87 octane towing and level 3 was 91+ octane performance?
Old Apr 7, 2010 | 11:36 AM
bogeyrider63's Avatar
^^x2 thats's what the owners manual say's.
Old Apr 7, 2010 | 12:20 PM
JackandJanet's Avatar
Level 2 IS 87 octane. Black smoke sounds like a very rich running engine to me.
You didn't say it, but I've seen somewhat similar symptoms when people tried to adjust the WOT fuel setting. If you possibly did that, try reentering your tune but this time, leave the WOT fuel alone.
- Jack
Old Apr 7, 2010 | 01:14 PM
FYI
Level 1 is Tranny Only.
Only the transmission's parameters are changed.
Peace!
Old Apr 7, 2010 | 02:14 PM
F150man21's Avatar
- Jack
in the past i might have changed the WOT, but i have left all that alone and ONLY changed the tire size and still get that rattle sound. i could care less about the rest, just want to run level 2 on 87oct.
and yes 88racing i knew that about level 1.
also thanks for the replies
Old Apr 7, 2010 | 08:18 PM
It may be an 87 octane tune, but if it's pinging, you need to use higher octane or remove the tune until you find out what's going on.
Old Apr 7, 2010 | 08:19 PM
shotgunz's Avatar
Good point.
Old Apr 7, 2010 | 08:37 PM
F150man21's Avatar
well right now i run it on level 1 and it runs fine, just not that much fun to drive
Old Apr 10, 2010 | 01:09 PM
Veteran: Army
sounds like you have a vacuum leak
Old Apr 12, 2010 | 09:34 AM
F150man21's Avatar
never even thought about that, is there a common place or do i start looking for the needle in the hay stack now?
