Thoughts on buying a used edge
Hello!
If it was VIN-Locked the display would have indicated same.
If it didn't , likely all it needs is an update to support yer truck's PCM strategy.
Need that cable!
Know anyone else with an Edge willing to lend the cable? If so and the update works, tell the seller to drop the price & you order another cable with the difference.
Good luck.
MGD v4.1
Need that cable!
Good luck.
MGD v4.1
It sounds like teh Hex code on your truck is not supported by the unit. Updating with Fusion may fix this. If teh owner wants to sell, he should find teh cord and uodate via Fusion. Then try again.
My brand new Edge, direct from Edge, wouldn't talk to my Expd, until I loaded the Fusion software on my Lap top, then connected the Edge, it update and everything worked great.
Ya know?
One from usb to mini usb. That would work.
Check the connection before hitching it up to the computer.
If you have a sandisk card reader that cable would work also.
Have a great evening!
Just thought I'd share some thoughts..................
Yep, your USB to Blackberry or to your digital camera will work fine. It sounds like you just need to update it via Fusion. I also bought mine used years back for around $225. Then one day while at the dealer, they reflashed my PCM which rendered the old Edge obsolete. I called Edge and they swapped it for a brand new one, no questions asked!! Sounds like you're getting a pretty good deal, good luck!
Yes, dont forget to set back to stock before any work is done at a dealership. IMO - I just take the unit out of the dash mount just for peace of mind that I will still have a unit when I come back. Lost a camera once while a vehicle was in service, lesson learned. I have not sent mine in for custom tunes yet, but it is on the to do list. I am not sure you mentioned it, but did he have the cd and manual? I mark up the blank pages with service history and notes (thrown codes, normal read outs, etc.) I believe it really is a good investment - if for nothing else, for the nice digital guages and ability to read / delete codes. Good luck!
Yep!!!!!
Same one toooo!!!!!
Just be sure its mini usb and not micro usb 2 different ends on the cables.
Same one toooo!!!!!
Ok so I ended up getting the edge today and he hooked it up and it worked. I traded the tires I took off my truck for the tuner so now I am thinking about sending it in to get upgraded.
Do you have or are you planning to have any intake/exhaust mods done? If so you may want to do those before you get a custom tune made. Otherwise you will have to get new ones made after your mods anyway. Just a thought.
