Edge Evolution for 1997 f150 4.6L
Old Feb 13, 2010 | 11:26 AM
mchynoweth's Avatar
Has anyone used an edge evolution programer on a 97 f150 or 98 f150? im thinking of getting one.
Old Feb 13, 2010 | 11:51 AM
mike97250's Avatar
I have a 97 250LD with the edge programmer. Great way to improve shift firmness I only use the tow tune but it is a different beast with the edge. I would suggest one to anyone.
Old Feb 13, 2010 | 12:35 PM
Glen R's Avatar
I had the first generation on my 98 F150, 4.6, 4x4. I saw a improvements in performance, driveability, and mileage. It dropped 2 tenths in the quater, picked up 1 mpg, on the 92 performance tune (Level 3). I consider it money well spent. I just traded my first gen, in on the current Edge, with dash mount. The gages are a definite improvement. If your considering the Edge, take a look at the PHP Gryphon, basically an updated Edge, that allows custom tunes. I will be sending my Edge in for updating, once I get the job situation striaght.
Old Feb 15, 2010 | 05:39 PM
mchynoweth's Avatar
well mine should be comin tomorow! pretty f#@***g excited!!
Old Feb 18, 2010 | 07:41 PM
mchynoweth's Avatar
just installed my edge yesterday! love the shifts and the acceleration is 100% better. does anyone have custom tunes that advance timing?
Old Feb 12, 2015 | 09:43 AM
noduh22's Avatar
I've recently tried to put one on my 1997 f150 and the programmer shut down half way through, then powered back on. I tried to start over and it says that it is under nonstock conditions. Does anyone know how I might be able to program it?
Old Feb 12, 2015 | 09:45 AM
MGDfan's Avatar
1. Try the recovery procedure in the manual.
2. Call Edge Tech Support during bidness hours.
g'luck
Old Feb 23, 2015 | 10:48 AM
grizzstang's Avatar
As you have probably found out by now, you are screwed. Your truck won't start and it won't load the program. I had to have mine towed to the dealer and have the PCM reprogrammed to stock. If you have bought an old Edge Monochrome you most likely have a bad cable. The 97 to 03 programmers had cable issues for years and I think that is why Gryphon stopped selling them for our year of truck. I am on my 3rd cable now and so far it seems to be holding. I am hoping they finally fixed this issue.
