MPG on a Gryphon?
Old Jun 23, 2009 | 10:04 AM
OffroadNewbie's Avatar
MPG on a Gryphon?
This may sound like a dumb question, but how do you view your MPG on a Gryphon? I can't seem to find it. Thanks.
Old Jun 23, 2009 | 10:07 AM
yetti96's Avatar
AMPG is average MPG and IMPG is instantaneous mileage. It get changed in the display settings. What 4 do you have showing now?
Old Jun 23, 2009 | 10:19 AM
RPM, MPH, Coolant Temp, and engine temp I think.
Old Jun 23, 2009 | 10:42 AM
yetti96's Avatar
Make sense on how to change it? Settings for the display, then click the position you are changing, then select new display type and I think the selection button is like "done" or something, then set display. Pretty easy while doing it, sounds retarded to explain it.
Old Jun 23, 2009 | 01:19 PM
JackandJanet's Avatar
Your Gryphon may have the firmware update that changed the names to AECON (Average Economy) and IECON (Instantaneous Economy). This was done because that update also made it possible to view these parameters in metric units and MPG doesn't hack it when you're reading Litres/100 Kilometers.
In any case, as Yetti said, you find these in the Display menu.
- Jack
