Do canned tunes stay on Gryphon?
Old May 13, 2009 | 10:16 AM
jlstang351's Avatar
Putting truck back stock and need to know if the canned tunes will still be there if i sell to someone. or will they have to get a custom tune?
Old May 13, 2009 | 11:54 AM
If you have never gotten custom tunes, the canned tunes are still there. If you have custom tunes, that is what is loaded and if the new owner does not have the same calibration as you, the unit will not work.
Old May 13, 2009 | 12:13 PM
jlstang351's Avatar
So they will have to get a custom tune? Or can PHP reload the canned tunes?
Old May 13, 2009 | 12:17 PM
Check out this thread at PHP's site.
http://dygytalworld.ehost-services13...t=canned+tunes
Old May 13, 2009 | 12:27 PM
jlstang351's Avatar
So i can put the canned tunes back on there myself right! If so ill give it a whirl tonight..
Old May 13, 2009 | 12:29 PM
Sounds like it to me. I have not tried it, but, I think it would be easier to sell that way.
Old May 13, 2009 | 12:33 PM
jlstang351's Avatar
Thanks alot for all your help Bluejay Ill let you know the outcome!
Old May 13, 2009 | 12:44 PM
This guy just had success, I bet you will too.
https://www.f150online.com/forums/ch...need-help.html
Old May 13, 2009 | 06:22 PM
jlstang351's Avatar
Ive never used the pegasus before..After downloading it it will not connect to the programmer. Its lit up red but I cant do any updates until it connects. Any advice?
Old May 13, 2009 | 06:26 PM
JackandJanet's Avatar
Did you set the tune in your truck back to stock? It has to be, you know.
And, if you are using Windows Vista, you'll have to do a few things to make Pegasus play with your PC. It's covered in the Pegasus manual on PHP's website. Finally, Pegasus won't work with 64-bit Vista.
- Jack
Old May 13, 2009 | 06:33 PM
rednoved's Avatar
I have a 64-bit Vista. What would my options be?
Old May 13, 2009 | 08:40 PM
To use Pegasus (with a Gryphon), you're going to have to find a PC that has XP or 32-bit Vista. Sorry bout that!
Pegasus is a very small application, so maybe you could persuade a friend to let you install it on his (older) PC?
- Jack
Old May 13, 2009 | 09:43 PM
rednoved's Avatar
I guess I would have turn the old XP back on.
Old May 14, 2009 | 04:05 PM
You are not the first or are going to be the last. My problem was mac based and what a head ache that was!
