Edge Evolution Problem
Old Feb 21, 2009 | 02:41 AM
mmalcolm24's Avatar
Just wondering if anyone else had this problem with there Evolution. When I installed the Evo in the Girl Friend's truck here Cruise Control stopped working. I was wondering if anyone else had this problem at all?
Thanks for any help you guys can offer.
Old Feb 21, 2009 | 02:49 AM
In the 3 years I have been reading about Edge problems, that is a new one. Check your fuses.
Old Feb 21, 2009 | 03:19 AM
mmalcolm24's Avatar
I will check that out in the morning. Didn't even think about that one. Its just weird how it started happening when I installed the Edge.
Old Feb 21, 2009 | 09:29 AM
JackandJanet's Avatar
You might also check the third brake light. If it's burned out, the cruise control won't work.
- Jack
Old Feb 21, 2009 | 10:26 AM
Groovy Chick's Avatar
Former Sponsor
Cool info, Jack. I learned something new today!
Old Feb 21, 2009 | 12:20 PM
mmalcolm24's Avatar
- Jack
She does have a putco led third brake light in the truck would that make the truck think the the brake light is burnt out? Because we installed them at the same time.
Old Feb 21, 2009 | 12:24 PM
- Jack
I just learned something too!
Old Feb 21, 2009 | 12:32 PM
last5oh_302's Avatar
Me too! Weird.
Now I'm trying to remember if I used cruise when my third brake light was burned out right out after the dealer had been working on it.
Old Feb 21, 2009 | 12:52 PM
Why would it be that way? I don't get the connection between the cruise and third brake light. Tht is just weird to me.
Old Feb 21, 2009 | 01:59 PM
mtylerb's Avatar
To sense when the brake is being pushed? <-- I'm guessing, otherwise I'm just as clueless as to why the cruise wouldn't work.
Old Feb 21, 2009 | 03:22 PM
I don't remember when or how I learned this, but I believe it's true. It's also possible that ANY brake light burned out will disable cruise, but I could be wrong.
It's controlled by the PCM in these trucks now, rather than a separate controller like we used to have.
What's worse, if ALL brake lights are out, you won't be able to get the truck's gearshift out of Park. (The shift interlock is disabled).
Installing LEDs with no load resistors can give similar problems, I think.
- Jack
Old Feb 21, 2009 | 03:35 PM
07BlkScrew's Avatar
- Jack
Well a light is really a resister in it's self. So since the third brake light is on the same ciruit as the cruise control (didn't know that) the reason it will not work with the light emitting diode is because the LED have a forward voltage drop of about 1.7mv a regular incandecent bulb will have a little more of a current draw. So
basically it thinks that there is a burt out bulb.
But Jack you are right, buy adding a resister of the correct value you will stop the problem.
Old Feb 21, 2009 | 03:39 PM
Many have messed with the 3rd light and had brake light problems. Strange that this has not come to light earlier and often.
Old Feb 21, 2009 | 05:48 PM
I already knew that about the 3rd brake light and cruise control.
I did learn about it through this site though.
Old Feb 21, 2009 | 07:02 PM
dhugo2's Avatar
- Jack
If this is true about all the lights being burnt out or removed that you shouldn't be able to get it out of park, then I have a broken interlock. I had both tail lights and third brakelight removed at the same time.... then had to move my truck to let someone else in the drive way. I backed out and pulled back in just fine. Does this mean I have a problem?
