how to install xcal3
Old Nov 16, 2008 | 04:04 PM
ColonelBlue's Avatar
Question how to install xcal3
i received my vmp xcal3 this week and it didnt come with a install manual.so i went to the web site and i read one on the sctflash web page and i have some ?s. do i have to unplug my fuse box? and when it says turn truck on ,do they want me to start the truck or turn the key till the battery kicks in? thanks im new to the programmer world so....
Old Nov 16, 2008 | 05:15 PM
KR-Texas's Avatar
I have the XCal2 and I have never unplugged my fuse box when flashing any of my trucks. I usually turn off all of my accessories like lights, radio, a/c, fans, etc.
When it asks to turn on the key, it just means to turn it to the first position without starting the truck.
FX4-Texas
Old Nov 16, 2008 | 07:06 PM
Drkharbinger's Avatar
I do not imagine it is different than my Livewire. As stated above you do not need to do anything with the fuses.
The device will tell you to turn your key on and NOT to start the engine.
Your device will prompt you on what to do.
SCT has a live chat option on their website as well if you have more questions.
http://www.sctflash.com/contact.php
The link on the bottom left will get you there
Load em up and have fun
Old Nov 16, 2008 | 09:21 PM
thanks guys i will give it a go tomorrow
Old Nov 17, 2008 | 12:11 AM
Arca_ex's Avatar
Yeah just plug it in with your truck off and it'll tell you what do to do on the screen. It's really easy.
Old Nov 17, 2008 | 01:40 AM
97XL's Avatar
Not sure if I got this from SCT or from TP but I was told before uploading a new tune to remove the fuel pump fuse or something like that, something to do with fuel pressure before the truck actually starts. The fuse is in the fuse box under the hood on the drivers side in front of the brake master cylinder. It takes about 30s and I've had no probs.
Old Nov 17, 2008 | 02:17 AM
dirtyd88's Avatar
never been told that...
Old Nov 17, 2008 | 12:58 PM
Arca_ex's Avatar
No you don't have to do that. I didn't do anything besides plug it in and follow the directions. Everything worked perfectly.
Old Nov 17, 2008 | 09:30 PM
KR-Texas's Avatar
I have never done that with mine. I have had Troyer tunes in the past and now, I have VMP with my new truck using an Xcal2. With both trucks, I turn off all of the accessories and simply follow the instructions on the SCT Flash screen.
I always return my truck to stock before I take it into the dealer for service, so I have gone back and forth between different tunes and "stock" many times over last two years on two different vehicles without removing any fuses.
KR-Texas (SOLD)
FX4-Texas - Needed a 4x4
Old Nov 18, 2008 | 01:20 AM
97XL's Avatar
Arca, KR check out page 2 of the X3 user manual in this link. Under Standard Vehicle Systems & Functions. Thats where I found the info on remove the fuse.
http://www.sctflash.com/PDF/3000-3015%20small.pdf
Old Nov 18, 2008 | 07:39 PM
Arca_ex's Avatar
It says you "may" want to remove the fuses. As in it's a suggestion.
Really what it's for is so that they're not liable for the retards that don't do the following:
1. Shut off A/C.
2. Turn off lights.
3. Shut off sound system.
4. Flash with engine not running.
Pretty simple if you ask me but you'd be surprised.
Also, what it means by "turn off electronics if applicable" is well... turn them off. Not "pull a s***load of fuses".
Old Nov 19, 2008 | 01:29 AM
97XL's Avatar
1. Shut off A/C.
2. Turn off lights.
I agree on the suggestion but for me its just 1 fuse so I don't mind taking that extra step just in case Murphy shows up and messes with the process. Just wanted to share the info.
Old Nov 19, 2008 | 03:32 AM
benzo911's Avatar
I just installed mine today (I have the xcal3). I plugged it in while the truck was off and followed the directions on the programer itself. As soon as you plug it in, it powers up and tells you what you need to do. Good luck.
