can you read a trouble code with an x-cal 2?
Old Oct 9, 2008 | 06:31 PM
cdnance's Avatar
just that. i had my service engine soon light come on and would rather not take it in unless i have to.
so... how do you do it?
thanks
Old Oct 9, 2008 | 06:40 PM
i.ride.suzuki's Avatar
Scroll down ->
Vehicle Info ->
Select ->
Read DTCs ->
Turn Key On ->
Select ->
Please Wait...
Old Oct 9, 2008 | 06:48 PM
cdnance's Avatar
appreciate that.
code came up as: P0506 IDLE CTRL SYS RPM LO EXP
dont by chance have any way of looking that up do you?
Old Oct 9, 2008 | 06:52 PM
Originally Posted by cdnance
appreciate that.
Disconnect your battery to clear KAM, clean your throttle body and then reconnect your battery.
Old Oct 9, 2008 | 06:57 PM
cdnance's Avatar
i appreciate it yet again. im gonna have to take it to the office in the morning. hopefully it will have stopped raining by then.
Old Oct 9, 2008 | 07:03 PM
Just FYI, make sure you remove the TB from the composite intake manifold, 8mm bolts, when you clean it.
Old Oct 9, 2008 | 07:36 PM
cdnance's Avatar
you know right off hand if it has a fiber gasket?
Old Oct 9, 2008 | 07:51 PM
4.6 2v : fiber-type gasket (as long as you do not rip it there won't be a need to replace)
5.4 3v : o-ring type on intake manifold
4.6 2v would be OK to clean on the vehicle as it does not have a composite intake manifold
