edge evolution problems?
Old Mar 27, 2008 | 03:40 PM
06yz250f's Avatar
ok so i dont no if this should be posted here or engine category but im driving to school today but i turn to pull out on a road and my truck basically dies. i had given it gas and it bogged down completely and wouldnt go. so i got into a parking lot reset my computer bak to stock (i had it on level 2 on my edge) and truck worked fine. any body experience this or know what could fix this from happening again? when i got home i re installed updates on it and plugged it bak in works fine no. by the way the wrench light came on in my dash when i checked diagnostics it came up w/ some code but then like unsure problem next to the number or code. any help would be great
Old Mar 29, 2008 | 05:57 PM
Justin FX4's Avatar
What kind of condition is your battery in??
you might contact edge customer service and see what they think,
There may have been a problem in the program that didnt surface until the truck got used to the new programming.
Just a thought
Old Mar 30, 2008 | 08:22 PM
jpdadeo's Avatar
Check the battery and ground; a weak battery or bad ground can cause problems
Old Mar 30, 2008 | 09:39 PM
Ftruck05's Avatar
My truck did this 3 times in 2 days about 2-3 month's ago. I had the same symptoms you described, the truck did'nt die though it was just idleing normal and the gas pedal was non-responsive. I pulled over and before I even shut the truck off I ran the diagnostics with my Edge. I want to say it pulled a p0141 code. the description was "IAC STUCK OPEN, LIMITED THROTTLE". I wrote the code down somewhere when I find it I'll let you know for sure.
