Evo and custom Options and PIDs
What about the Mileage Max that Edge has created for Dodge. What is the possibility of that rolling out for the 1997-03 f150 and the 04-08 f150.
And if that is somthing that is in the works will it work well with the Evolution?
Originally Posted by openclasspro#11
heck he might as well buy scangauges and private label them as gryphon II's
Once I get caught up on some stuff here, it sure it'll be worth the investment to pick one apart and add similar functions to the Evo.
Originally Posted by Screw-Me-05
Why cant i change to different PID's ? im stuck with the four that comes pre loaded rpm,mph,ect,tct WTF
When all else fails, RTFM!
- Jack
Don't think so! From the Main Menu, choose Setup. Then, select Display. Choose the number of functions you want to montor on the next screen and press Enter. You'll now see a list of the parameters you are monitoring. Select one you want to change and press Enter. A list of the available parameters will now be displayed and you can choose one. Do this for all the parameters you want to monitor. Then, check "Set as Display" and press Enter.
- Jack
- Jack
