03 F150 Crew 4.6 Edge Evo Speedo Correction, Settings not staying changed.
I have a 2003 F150 Supercrew 4.6L 4X4 3.55gears K&N FIPK Ready Lift Keys with Mickey Thompson Baja ATZ 285/75R16 D(33X11.50R16LT).
My problem is since I've increased my tire size my speedo is off, off course. I have the Edge Evo, when I change my gears and tire size and go in to check the settings they are back to what they originally were. Which are wrong in the first place. It say 3.31gears when I have 3.55. Speedo is about 12mph off. I've changed them with Lightning 3 v2.00.0072, change back to stock then to stage 3 with customs all change back to default. No change.
Edge Evo
Bootloader v1.00b
Product E4.06.06
Firmware 06
Please Help
Dazed
Edge Evo
Bootloader v1.00b
Product E4.06.06
Firmware 06
Please Help
Dazed
There is no easy way to check your current settings. This is a major oversight on Edge's behalf, and I have suggested a fix. We'll see...
When you enter the Custom Program menu, you're seeing all of the parameters reset to their default values. This has nothing to do with the settings that you are currently running. You can exit out and nothing will change. The settings that you wrote to your pcm the last time are still there, you're just not seeing them.
If you would like to create a new custom program and starting building with your current settings, select the Load Previous Settings option from the Parameter menu. Your parameter values will now reflect the changes you made last time. This could also work as a backwards-*** way to view your current settings, but it's a PITA.
Make sense?
Make sense?
