Edge Evolution Custom tunes
Hey all, I just got my edge the other day and was wondering if anyone had some custom tunes they wouldnt mind sharing. I dont know enough about all the technical stuff to try customizing myself.
I have a 2003 F-150 screw, 20" KMC wheels with 32" tires, with flowmaster 50 series muffler dualed out the back, K&N air filter, and some time back I removed the air intake silencer.
If anyone has customized their edge and saw an improvement in performance/power and doesnt mind sharing their secret, let me know...
thanks
thanks
I assume you are referring to the custom settings the unit allows you to do, not a custom tune. Do an advanced search on "Edge custom settings" and see if you don't get a lot of reading material. It has been discussed a lot.
Since you say you removed the silencer, I assume you have a 4.6. Also, I am assuming a K&N drop in, not an intake. Also do a search on the model number of the Edge. You definitely need to change the settings for your tire height and be sure you enter the correct gear ratio for what is in your truck. The other settings are up to you. Read some of the previous posts and see if you find what you are looking to achieve.
