Edge problem
Old Nov 23, 2007 | 05:13 PM
f150monster232's Avatar
Edge problem
got my edge 2 weeks ago, adjusted it for my new gears and tires and set it on level 2, the past week its been not starting up right away, and now the edge dosent even light up now, can anyone tell me whats wrong, or what 2 do
Old Nov 23, 2007 | 05:36 PM
Irish FX4's Avatar
When you say it does not light up do you mean the back light or there is no display at all ie the guages display?
Old Nov 23, 2007 | 07:25 PM
JackandJanet's Avatar
I'm not trying to be a jerk or anything, but have you checked that the cable is still plugged in at both ends? (At the Edge module and at the computer port). Other than a total failure of your Edge module, I can't think of anything else that would cause your symptoms. If it's a total failure, I suspect Edge will replace it at no charge.
- Jack
Old Nov 25, 2007 | 06:26 PM
ASEMechanic's Avatar
Talking
Okay,
  1. When you say "not starting up right away" do you mean the truck or the Evolution?
  2. When you say "edge doesn't even light up" do you mean the backlight or the LCD display?
Unplug the unit from the OBDII port and reconnect. If that doesn't work, also check the connector on the back of the unit. (just pop it out of the pod and give the cable a wiggle) If the problem persists, Edge will certainly replace the unit for you.
If you live close enough, I am located in Winder and would certainly be happy to take a look at it for you.
Take care.
Bill
Old Nov 25, 2007 | 08:17 PM
they edge dosent show a display i already took the wires out and reatached them to see if that was the problem,
when i said dosnet start up right away it dosent turn over, and only did that when the edge was installed
Old Nov 26, 2007 | 07:50 PM
Please forgive me - but I haven't a clue what you are saying :o
I get the "no display" part - that's referring to the Edge, and, I understand you disconnected and reconnected the cable - right? AND, you had the ignition key in the "ON" position BEFORE you connected the Edge cable, right? And - after this, still "no joy", right?
But now I'm really confused. what doesn't "turn over"? The starter? Does it engage and the engine doesn't start? And it seems this "symptom" is only present when you have the Edge connected - is that correct?
As I said, forgive me - I'm just a simple Aerospace Engineer/Computer Programming Instructor who can usually figure out what to do if I understand the symptoms. And, I bet YOU a beer that Bill could help if the problem was stated a bit more clearly! (Been waiting for a good time to use that one!)
- Jack
Old Nov 27, 2007 | 12:41 PM
MastaGolla's Avatar
Registered User
Did you update the Evolution on Edge's website or by using the CD that was givin to you when you purchased the Evolution?? It is called the Lightning software. I would highly recommend on doing that. If you bring the Evolution back to stock. Does it still have the rough hard start? If it doesn't, my bet is that it has an old version of software. Did you change anything in the custom options as in Spark Advance?
Old Nov 28, 2007 | 08:40 PM
I looked for the softwear online and got in on the edge website but it wouldnt pull up after downloading it, the edge programmer its self dosent light up orshow and display, the truck is working fine, just didnt turn over right away like it did but i think that was my battery. What should i do about the edge peace though sence its not working
Old Nov 28, 2007 | 08:57 PM
Ftruck05's Avatar
If the Edge is not working at all the first thing you should check is the fuse. The cig lighter and OBD are hooked up on the same fuse, if you want to know what fuse to look at and what amperage it is rated for RTFM! If its not the fuse than double and triple check the connections. Make sure the key is on whenever you plug the unit in. I always hook up the Edge first, turn the key on, and than plug in the OBD. Hope this helps.
Old Nov 28, 2007 | 11:58 PM
Thats wierd to think about becauce i was pushing in my cig, lighter and it never popped out and thats the same exaxt time it stopped workinf. what do i do about the fuse then?
Old Nov 29, 2007 | 06:09 AM
I don't understand why they do it, but the power to the OBDII port is on the same line as the lighter and Power Point outlet.
The manual will indicate what # fuse is the lighter/accy fuse. Replace that and you should be good to go.
Once the unit is working again, return the truck to stock and see if the starting hesitation still occurs. If it does, then you know the problem is likely with the battery, like you said.
Good luck.
Bill
Old Nov 29, 2007 | 10:58 AM
Ftruck05's Avatar
Yes this is a really F'd up setup. Took me about 10minutes to figure out. I plugged my radar detector into the cig lighter and the Edge turned off. WTF! I pulled over and checkd both of the connections and they were good so I busted out the manual and started looking for an OBD fuse. Ford doesnt call it an OBD, I dont remember the exact name but I think it was scanport or something like that.Again WTF FORD???
Old Nov 29, 2007 | 11:19 AM
They really need to put the cool diagrams on the back of the fuse panel or somthing so you don't have to drag out the manual every time you pop a fuse. It's really a pain in the tush...
Old Nov 29, 2007 | 08:42 PM
Thank yall so much for the help, i feel like a retard
Old Nov 29, 2007 | 08:52 PM
Ftruck05's Avatar
No problem, glad to help. I have learned alot from this site and find something new every day.
