ScanGauge Opinions
Hello sir!
NO sir! Fellow Troyer Performance customers treat each other with respect !
There are Ford PIDs pubished in the public domain - you should be able to X-guage any of them if the sensor is present and/or the PID is active in the PCM, depending upon model...
10-4 on the snow - after a mostly dry winter, we finally got whacked.
Cheers, bud.
MGD v4.1
Cheers, bud.
MGD v4.1
I have gotten closer to my snowblower this year!
About Troyers ... I must say I was pleasantly surprised with the time and attention given to me when I walked in that afternoon. I look forward to going as an observer come dyno day .... when / if it happens.
Later then ......
Thanks for the help and I assume that this is what I need to get the display I want but have to admit it is over my head and don't have a clue what to do now.
Thanks,
Thomas
Thanks,
Thomas
Ford CANBUS VCT PID's:
RCAM 16CD VCT Solenoid Commanded in Crank Shaft Degrees DEGREES
VCTA 16B1 b6 VCT Control Circuit Monitor ON/OFF
VCTENA 16B1 b5 Conditions Correct to Enable VCT YES/NO
CAMDCR 16CF Commanded Duty Cycle for VCT Solenoid %
CAMERRR 16CE VCT Error in Crankshaft Degrees DEGREES
Combine above values with the info presented in the Scangauge x-Gauge coding manual to generate these VCT displays
==> http://www.scangauge.com/support/pdfs/XGaugeCoding.pdf
MGD v3.0
MGD v3.0
