After 1 week with the Edge...
Old Jan 7, 2008 | 09:58 AM
051fdrof's Avatar
If your vibration is being caused by the Evolution, it's the first I've heard of it. I would look elsewhere.
Old Jan 7, 2008 | 05:06 PM
openclasspro#11's Avatar
are you /
Originally Posted by Jeff2005F150
I downloaded the lastest update and it took the away the bucking and jerking when I adjust shift points. I still have the vibration when I hit the gas hard though. Do you think it could be something else? The vibration only happens at high rpms.
are you running a cai aftermarket intake?if so try running with stock 1
Old Jan 7, 2008 | 06:31 PM
Jeff2005F150's Avatar
The truck is completey stock no CAI or exhaust. I think I am going to take it to ford. The truck seems to do it a little when the pcm is programmed back to stock although not as much as when programmed with the edge
