After 1 week with the Edge...
I've been running level 2 on my 2005 5.4L Supercab XLT.
I loaded level 2 last Friday and thought I would provide a little feedback so far.
1. Power is much better.
2. Fuel economy is better, but I need to adjust my tire size. I think I'm off by a little bit.
2. Shifting feels better overall. I love the way it shifts accelerating onto the highway from 2-3, and 3-4. Similar feeling on sweeping country roads.
3. Driveability is better on highway, country road, and around town, except it seems that during normal driving, i.e. normal acceleration from a stop, the 1-2 shift comes too high in RPM. It comes around 2500-2700, which I think is too high. This gets annoying in stop and go traffic and driving in neighborhoods with lots of stop signs.
Can the shift point for non-WOT be adjusted?
CJ
CJ
Originally Posted by Irish FX4
Took me a sec.
A Classic: --> http://www.altgeek.org/methuselah/rtfm/
CJ
CJ
Wow that seems kind of high for a standard shift point. I am running level 2 and with normal excel I think it shifts a little under 2000 and if I really baby the throttle it will shift at like 1500 from 1-2 and thats even with the STD shift points raised very slightly....so I would suggest just going into the custom settings and settings the 1-2 STD shift point setting lower and test it out.
I have the same concern about the high rpm when shifting from 1-2. I don't like the stock setting and the level 2 seems a little high for me but some wheres in between would be great. I tried adjusting the std shift point to -1 to have the truck shift a little sooner but when I took it for a test drive the trans seemed as though it was slipping on take off. It would rev up and jerk alittle and then take off. I set is back to the canned level 2 settings and it worked great still had the high rpm though.
Any thoughts
Any thoughts
I did RTFM but it didn't help.:o
You would think that adjusting the std shift points would just decrease the rpms it shifts at and not case the truck to buck and jerk like it does. Whenever I just use the level 2 settings it works great just the rpm's are a little high.
Any other thoughts
Any other thoughts
I have noticed the 1-2 shift being a little higher than usual on level 2 and I think it is to help get loads moving while towing. I just compensate by adjusting my driving style a little bit to fit the shift in better. I have never tried level 3 to see if the 1-2 shift is the same there.
Any other thoughts
Any other thoughts
That was a bug and it was fixed back in October. Download the current firmware and software releases and it will be gone.
Consider yourself lucky, when I had my F150, I had horrible problems with driveability with the Edge ..
I love it....
