xcal2 error problem
Old Oct 22, 2007 | 07:31 PM
07_HD's Avatar
xcal2 error problem
hey guys, im sure ive done something wrong but not sure what it is. i just recieved my tunes from troyer today and i downloaded them to my device...and when i hook it up to my truck and go to "program vehicle", hit select, scrool down to 87 performance, hit select it says "error - ecm not supported" can anybody help me out...thank you in advance
Old Oct 22, 2007 | 07:47 PM
MGDfan's Avatar
Any idea if you had a reflash between the time you ordered and now?
Best advice - call them now & leave a voicemail - with a callback number.
This has happened before - they know how to fix it.
--> https://www.f150online.com/forums/sh...d.php?t=301085
Good luck.
Old Oct 22, 2007 | 07:51 PM
i.ride.suzuki's Avatar
Guessing you have a 2007 F150...
Check the device firmware: if 1.14 update it to 1.15 via sctflash.com
Old Oct 22, 2007 | 07:59 PM
07_HD's Avatar
i just had a oil change on friday morning at the dealer, my first oil change so far. maybe they reflashed?? is it simple to fix the strategy code or does Mike have to re-do everything now?
Old Oct 22, 2007 | 08:01 PM
07_HD's Avatar
when i check on the device it says 1.14, i guess i gotta figure out how to update it, thanks...and yes it is a 2007
Old Oct 22, 2007 | 08:04 PM
MGDfan's Avatar
If that's what happened, then TP needs to re-do the tunes. I would suspect a priority would be applied.
And check as suzuki suggests -
EDIT - just saw your reply - that's odd - I would mention that to them as you need to be @ that revision.
Refer to the SCT website for both the firmware update file, the utility and the instructions on how to proceed. Recommend using a WinXP pc.
Please let us know how you made out.
Good call, Suzook!
Good luck.
Old Oct 22, 2007 | 08:30 PM
07_HD's Avatar
thank all of you guys for helping me out, suzuki, you came through for me, iappreciate it. i updated my device and voila, shes alive, took it around the block and i can definately feel the firmer shifts. cant wait for the drive to work in the morning...kinda glad i have an hour drive each way now i have it on 87 performance for now, so hopefully its good enough to stay on and i dont have to go to 93 (that would kill my already small bank account) thanks again to everyone who helped me out. you guys rock!
Old Oct 22, 2007 | 08:35 PM
MGDfan's Avatar
Thanks for posting that resolution - good job, and good call !
When you get a chance feed this back to TP - it'll help.
MGD
Old Oct 23, 2007 | 12:24 AM
TexEdition's Avatar
Not really on topic, but the Xcal2 device I received last Friday included a neat little red cap that fits over the OBD II port and says "DO NOT REFLASH - CONSULT OWNER"..
If my dealer ever asks I'll say I got it for a dime at Pep Boys ('cause they sell cheap trinkets)... that I just want to be informed what they're changing before they do it..
Old Oct 23, 2007 | 08:19 AM
05supercrew's Avatar
Thats great, I was thinking of putting tape over mine but that works better.
Old Oct 23, 2007 | 06:08 PM
Glad it worked out for you.
