Installed Edge, Won't start now??
Old May 29, 2007 | 12:45 PM
01crew4x4lariat's Avatar
Originally Posted by bigmark
I have the same truck as you and unit and I swear it never said anything about taking out the fuel pump fuse.I hate hearing these night mare stories, makes me want to not flash mine again and stick with the custom tune i created.Did you recently buy the unit new?Im wondering if your software was old.Mine says july 06 for software.hope you have some better luck
i bought it off ebay, it was made in september of 04. the fuse thing doesn't make sense to me either, because not a lot of fuel would leak anyways, i leave ignition on all the time for other stuff. but it said it must be removed.
i called edge they are sending me a new unit and stock writer, i hope this works. its very frustrating!
Old May 30, 2007 | 12:28 AM
mgp32's Avatar
Old May 30, 2007 | 12:51 AM
bigmark's Avatar
Im so happy i got mine during that 318 dollar price that auto anything put on before the hike,so far i have not had any problems as far as i know.good luck man
Old May 30, 2007 | 01:14 AM
Exclamation
I just installed my edge eef2000 and everything installed easy. I read the warning to remove the fuel pump fuse first and did so. Installed the performance level 3, changed the tire size, and said it was completed. Reinstalled the fuse, and went to start my truck and it wouldn't start? So now i don't know what to do, or what went wrong. My battery of course died on my. If anyone has had this problem or knows of what to check or fix i would appreciate the help on this one.
Update: I have fixed my truck, I ended up taking it to ford, and they had to reprogram my pcm. it cost me $90, but am so glad it works again. Now when my new evolution arrives tommorow, im not sure if i want to try again and install it. Im nervous it will happen again. Thanks all for your help, i expected it to take me 10 minutes and my truck would be unleashed, now days later im am dissappointed.
Old May 30, 2007 | 10:28 AM
crash_lucky13's Avatar
i had the same thing happen on one of my diablo chips before. just make sure the ignition is off and you follow the steps precisely.
my little clip that keeps the wire attached to the module broke and everytime i hit a bump it comes undone. trying to get a hold of edge now to get a replacement unit.
Old May 30, 2007 | 06:39 PM
mgp32's Avatar
Dont worry about taking out any fuses...I didnt and no one else did. Just plug it in and follow the instuctions on the screen. Good luck...
Old May 31, 2007 | 01:21 AM
Bluegrass's Avatar
A possibility; Is there a code stored? If yes and it is P1639, the VID software block is corrupted.
If that is the case a dash Hec code will also point to the same problem but from outside the PCM because the two are linked and look at one another for a check.
The PATS usually will flash a code 1:6 if you leave the key on at least 1 minute or do the dash Hec code test and get a read-out on the odometer.
This code says the Pats and the PCM are missing matching information such that the PCM will not allow starting.
This disallowence of starting is what it's supposed to do when there is a mismatch.
Again this is only if you see these indications.
Only way around it is a reflash.
If you go and have this done, take two keys for the complete reflash because the key codes even change or you still won't be able to start the motor even after a re flash..
Good luck.
Old May 31, 2007 | 08:27 AM
hwm3's Avatar
Does EDGE cover the cost of a dealer reflash in cases like this?
Old May 31, 2007 | 08:24 PM
Ftruck05's Avatar
^ You're funny
Old May 31, 2007 | 09:24 PM
if you read on their website:
WARNING
THIS IS A HIGH PERFORMANCE PRODUCT. USE AT YOUR OWN RISK.
Do not use this product until you have carefully read the following agreement.
This sets forth the terms and conditions for the use of this product. The installation of this product indicates that the BUYER has read and understands this agreement and accepts its terms and conditions
DISCLAIMER OF LIABILITY
Edge Products Inc. and its successors, distributors, jobbers, and dealers (hereafter SELLER) shall in no way be responsible for the product's proper use and service. THE BUYER HEREBY WAIVES ALL LIABILITY CLAIMS.
The BUYER acknowledges that he/she is not relying on the SELLER’s skill or judgment to select or furnish goods suitable for any particular purpose and that there are no liabilities which extend beyond the description on the face hereof and the BUYER hereby waives all remedies or liabilities, expressed or implied, arising by law or otherwise, (including without any obligations of the SELLER with respect to fitness, merchantability and consequential damages) or whether or not occasioned by the SELLER's negligence.
The SELLER disclaims any warranty and expressly disclaims any liability for personal injury or damages. The BUYER acknowledges and agrees that the disclaimer of any liability for personal injury is a material term for this agreement and the BUYER agrees to indemnify the SELLER and to hold the SELLER harmless from any claim related to the item of the equipment purchased. Under no circumstances will the SELLER be liable for any damages or expenses by reason of use or sale of any such equipment.
The SELLER assumes no liability regarding the improper installation or misapplication of its products. It is the installer's responsibility to check for proper installation and if in doubt, contact the manufacturer.
Old Jun 18, 2007 | 11:49 AM
PBPoisonn's Avatar
To reset your Anti-Theft system, turn the ignition switch to the "On" position (DO NOT START). After 30 - 40 seconds the Anti-Theft light should stop flashing, turn the key off and remove thr key. Wait 30 seconds, insert key, and attempt to start.
Old Jun 18, 2007 | 01:26 PM
huntingky's Avatar
I agree with this big time! I have an Edge on the way and it gives me a sick feeling in my stomach thinking about something like this happening. AND explaining to my wife how I just killed our recent $24,000 purchase which was running fine before I started tinkering with it! NOT a pretty picture in my mind.
Old Jun 18, 2007 | 05:30 PM
Sharkmon's Avatar
Question Yep! Played with mine a LOT and I'm hosed. IDEAS?
Ok, so I have had my EDGE for several months (2006 Supercrew 5.4L) and it worked well. But being the adventurer that I am, I am having issues with the truck. I don't blame it much on EDGE, but it is definitely a contributing factor, as without it, I wouldn't be in this position!
Anyway, my truck started having electrical fits (drained battery one morning with nothing left on all night about a week or so ago)...Failsafe Mode several times over the last several months (oh yeah, baby!). Sometimes the unit wouldn't even power up when I started the truck. I would have to pull it from the pod, unplug the cable and plug it back in to get it to turn on.
Now it goes into Failsafe Mode EVERY time I try and alter the settings on the truck. I can't even change tire size without it flipping out and dumping into Failsafe within one minute or under one mile. But after I change it back into Stock Mode, the truck runs fine. I unplugged it after I put it back to stock the other day.(Saturday, June 16, 2007)
WHAT'S UP WITH THAT?
IDEAS ANYONE??
Save the lectures! Just use me as an example and get on with it! Spending money on a Flash isn't a big deal!
Old Jun 18, 2007 | 08:20 PM
C-17 Pilot's Avatar
Just throwing a few ideas out there:
1. It sounds as if the problems with the Edge started as a result of the electrical problems you experienced. It has been documented by others here that the Edge and electrical problems (e.g., battery failure) don't play well with one another. The symptoms you described sound very similar to what happened to a few other folks when their batteries died. As you're probably aware, the OEM batteries are not known for their longevity.
2. The good news: If your truck is running fine when returned to stock, then you won't need a reflash.
Here's what I would try first:
Use the Lightning software to update your Edge. Even if you're already running the latest updates, use the software to download the updates into the device *again*. This will help if the firmware on the Edge was somehow corrupted by the electrical problem. If that doesn't help, then I would guess that your Edge is defective. If you're still under warranty, Edge Products will replace it for free.
Old Jun 28, 2007 | 01:22 AM
01sprcab14's Avatar
i got my edge yesterday and it was a defective unit. it killed the pcm so tech suport mailed me a new unit and a stock writer overnight it was here in like 15 hours i installed the stock wrtier and that didnt work then tried installign the new edge to see if it could return it and that didnt work so now i had to get it towed to the dealer they have to clear the pcm completly and ad in evrtythign again its gonna cost 140 edge said they woudl give me 75 toward the tow even tho triple aaa towed it and 75 toward the reflash. the thing that sucks is im out of my truck for 2 days and the difference on the cost of the reflash. now i dont even want to put it in my truck ford gave me alot fo **** for it too. ford is a bunch of jerk offs and i will never deal with ford again
