Edge problem
Old Mar 16, 2007 | 09:54 PM
Tgarr's Avatar
Edge problem
I just got my new Edge programmer installed in my '06 SCAB W/ 5.4. Everything appeared fine until I turned the alerts option on. Now, everytime I start the engine, I get an alert stating SPARK 16383 or around there. I tried all the settings w/ same response, so I went back to stock and used the Edge just for gauges, same alert. Alert only stays on until fast idle kicks down, then everything is great. Is this something to do with the "cold start" program. Anyone else have this problem? Otherwise the Edge rocks.
Old Mar 16, 2007 | 10:12 PM
kd4crs's Avatar
I have not seen that with the EDGE on my 06 SCREW. You should call EDGE.
Old Mar 16, 2007 | 10:23 PM
gilsnuxs's Avatar
same here, no problems. '06 Scab 5.4
Old Mar 17, 2007 | 02:35 AM
ffemt000546's Avatar
No issues with my EDGE on an06 SCab
Old Mar 17, 2007 | 07:32 PM
JMay97's Avatar
Same problem
I have the exact same problem you described. I just turned the alerts back off. Hope you find the solution and post the fix.
Good luck,
Old Mar 17, 2007 | 07:59 PM
Tgarr's Avatar
Thanks for the replies. I'm going to call Edge on Monday and see what they have to say. I love the tuner, just a little nervous about the alert. I'll keep you posted.
Old Mar 19, 2007 | 12:25 AM
kitchenboy's Avatar
There is already a post about that problem. I think they said something about the edge picking up the sinal from the computer before the engine actually starts. Thats why you get the alert. The post said they leave the alerts off. Do a search you'll find it.
