Edge problem
Old Mar 6, 2007 | 03:48 PM
04FX4Screw1's Avatar
Edge problem
I got big problems my Edge went one the blink made the truck start clicking and now it won't run worth a damn gave me an error code of P2106 THROTTLE ACTIVATOR CONTROL SYSTEM-FORCED LIMITED POWER what does that mean any and all help will be appreciated
Old Mar 6, 2007 | 03:54 PM
FX4_Guy's Avatar
Search for P2106 in the 2004+ forum. A few people have had this error code pop up in there. It'll explain what to try.
Old Mar 6, 2007 | 04:00 PM
beckerjs's Avatar
Why blame Edge for a TPS
Old Mar 6, 2007 | 05:15 PM
Edge is crap, after being on the phone with them for an hour reprogramming that POS now my truck wont ever start THATS WHY BLAME EDGE
Old Mar 6, 2007 | 05:59 PM
Sheez, man. Edge doesn't make a TPS go bad, Ford does.
Old Mar 6, 2007 | 06:23 PM
marwilli1's Avatar
I had the same code come up on mine, along with 5 others. it was pretty much my fault though. i left it in storage for a few months without returning it to stock and the battery died. when i went to return it to stock, the truck had lost part of its e-prom memory and thought it was a 2wd w/3.55's, no cruise and 17" wheels. when its actually a 4x4, 3.73's, cruise and 20's.
to make a long story short it had to be reprogrammed. but i still havent put my edge back in yet, im a little apprehensive of it.
Old Mar 6, 2007 | 08:12 PM
erich886's Avatar
Go to the dealer and get your TPS replaced. That was a common problen on the 04 F150. Here is Ford's TSB on it. Hope this helps out
TSB
05-14-4 WRENCH LIGHT ON WITH BOTH DTC P2106 AND P2135 - VEHICLES BUILT 11/29/2004 AND PRIOR
Publication Date: June 30, 2005
FORD: 2003-2005 Thunderbird
2005 Crown Victoria, Mustang
2004-2005 Explorer, F-150
2005 E-Series, Expedition, F-Super Duty
LINCOLN: 2003-2005 LS
2005 Town Car, Navigator
MERCURY: 2005 Grand Marquis
2004-2005 Mountaineer
This article supersedes TSB 05-09-15 to update the Issue and Dealer Coding.
ISSUE:
Some vehicles built 11/29/2004 and prior may exhibit the wrench light on with both P2106 and P2135 diagnostic trouble codes (DTCs).
ACTION:
Replace the throttle position sensor (TPS) following the instruction sheet included in the TPS service kit. Reprogram the powertrain control module (PCM) to the latest calibration using WDS release B36.11 and higher, or B37.2 and higher. This new calibration is not included in the B37 CD. Calibration files are also available at www.motorcraft.com.
CAUTION: FAILURE TO FOLLOW THE TPS REMOVAL AND INSTALLATION PROCEDURE WILL RESULT IN DAMAGE TO THE TPS SCREWS.
PART NUMBER PART NAME
3L5Z-9B989-AA TPS (Kit)
LABOR OPERATIONS CLAIMING CHART
Operation Labor Operation Application Time
051404A Check For Codes, Reprogram PCM, 2003-2005 LS 3.9L 1.4 Hrs.
Replace The Throttle 2003-2005 LS 3.0L 0.7 Hr.
Position Sensor, And 2003-2005 T-bird 3.9L 1.4 Hrs.
Perform Final Quick 2004 Explorer 4.0L 0.6 Hr.
Test (Do not use 2004 Explorer 4.6L 0.7 Hr.
with: 12650D, 12650D84, 12650D1, 12650DX1) 2005 Explorer 4.0L And 4.6L 0.7 Hr.
2004 Mountaineer 4.0L 0.6 Hr.
2004 Mountaineer 4.6L 0.7 Hr.
2005 Mountaineer 4.0L And 4.6L 0.7 Hr.
2004-2005 F-150 4.6L 0.6 Hr.
2004-2005 F-150 5.4L 3V 0.7 Hr.
2005 Mustang 4.0L 3V And 4.6L 3V 0.7 Hr.
2005 Crown Victoria 0.7 Hr.
2005 Grand Marquis 0.7 Hr.
2005 Town Car 0.7 Hr.
2005 F-Super Duty 5.4L 3V And 6.8L 3V 0.7 Hr.
2005 E-Series 4.6L, 5.4L and 6.8L 0.9 Hr.
2005 Expedition 5.4L 3V 1.0 Hrs.
2005 Navigator 5.4L 3V 1.0 Hrs.
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage
DEALER CODING
BASIC PART NO. CONDITION CODE
9E928 42
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford, Lincoln, or Mercury dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
Copyright © 2005 Ford Motor Company
