Edge Evolution Flash
Wondering what to do when I bring my truck in for service. Should I just reset to factory setting or should I unplug the unit too? I read that if they flash the computer it could mess up the Edge.
Thanks for any info.
I always return the truck to stock and remove the EDGE no matter what the dealership is doing. No since in taking a chance on a "stealth" reflash or giving them any excuse to cause grief over having a tuner.
So just go into the settings and return to factory settings and unplug?
When I plug it back in is there anything special I need to do or just put it back to the setting I had before?
You go back into program and select (0) Stock Program and hit enter. It reloads your stock program to your truck. You can remove the module or leave it. I leave mine since I am out of warranty anyhow. Then when I get the truck back, I go to whatever level i want to. If you will check the manual, it tells you to do all of this anytime you go to the dealer.
thanks, im just goin in for an oil change but I think I will unplug and remove since its only got 6000 miles on it.
Suggestion of burning of few tanks of normal gas at the "stock setting" is a good idea too.
Something about the truck's "learning feature" (which I understand is based on the last 500 miles driven).
Always remove the Edge...here in Kalifornia most super chips are illegal...so, poof goes the warranty if you are not careful.
