question about edge
Old Oct 17, 2006 | 08:27 PM
deisel88's Avatar
question about edge
i ordered the edge and keep reading about 04's running lean my question is if my truck gets to running to lean will the edge pick this up in the diagnostics and the check engine light come on also what is the signs of the truck running to lean, what do i need to look for.
Old Oct 17, 2006 | 08:54 PM
Silverfish's Avatar
Turn on your pm......I will give you my opinion. I don't want to be ripped apart by the other side.
Old Oct 17, 2006 | 08:59 PM
kd4crs's Avatar
If the truck runs lean enough to set a code or turn on the check engine light, the EDGE will allow you to read and clear the code(s). The EDGE tuning will NOT make the truck run lean. Intake changes without custom tuning to correct the air to fuel ratios are usually the cause of runnning lean. The EDGE cannot correct for lean conditions.
Old Oct 17, 2006 | 09:56 PM
ozzeran's Avatar
Who cares, I put on my flame suit for the Edge and it's bs. Problem with online forums is people like to talk positive with stuff but wont talk negative about it. Sorry but the Edge is a POS, there you have it again
Old Oct 17, 2006 | 10:05 PM
deisel88's Avatar
i really don't know how to turn on the pm plus this was not to start anything just wanting to be safe with my truck. so with the edge programmer it will not make my truck run anymore lean or rich than what it already is before the programming.
Old Oct 18, 2006 | 02:52 AM
NASTY-FX4's Avatar
Buy the Edge,run it stock setting with the Head Temp.shown on display.Let it get to full temp,and get a reading say at 90mph.Then make a run with the tow or performance tune.If the reading on the heads is higher at 90mph,then most likely it is running lean.If you don't like put it on Ebay.
Old Oct 18, 2006 | 07:48 AM
Silverfish's Avatar
you are a big "Richard Cranium" did not take much to get you to rise.....how shocking!
Old Oct 18, 2006 | 12:40 PM
ozzeran's Avatar
Yeah I know, I just hate having bad luck with aftermarket parts.
Old Oct 18, 2006 | 12:50 PM
I understand, and am sorry you had a problem. It seems to me that Edge did not do all their home work when they produced the unit for the trucks prior to 2004 model. They apparently advertised some things that the older trucks were not capable of doing before they had a complete product. I have a 2005 truck and the Edge has performed as advertised and I love it. I too hate to have problems with anything I purchase, we all do.
Old Oct 18, 2006 | 12:55 PM
beckerjs's Avatar
what temps are we looking for?
Old Oct 18, 2006 | 04:16 PM
2001Screw4x4's Avatar
No, it can also be higher due to the advanced ignition curve. Just because it is hotter does not mean that it is lean. The only way to know for sure is to read the plugs or use a wide-band O2 sensor and monitor it.
