Just installed the Edge
Old Oct 11, 2006 | 08:33 AM
MGDfan's Avatar
Originally Posted by Silverfish
Why do so many not datalog the Xcal then?
That's a very good question, since it is highly recommended, and since any retuning (if required) is included in the purchase (within 60 days) from TP. And since the comprehensive documentation provided by same makes it easy even for a relic like me to do.
I can't speak for any of the other sources of X2's and custom tunes ... but there really isn't any point in going with anything but the best.
Cheers
Bubba
Old Oct 11, 2006 | 10:31 AM
Silverfish's Avatar
The Edge is the best for what I need and want.....
Old Oct 11, 2006 | 10:32 AM
I could not say it any better.
Old Oct 11, 2006 | 11:29 AM
thetruck's Avatar
X2!!!!!!
Old Oct 11, 2006 | 11:32 AM
MGDfan's Avatar
Originally Posted by thetruck
X2!!!!!!
Ahhh - another '04
"Do you know where your A/F is ..?"
Guys - not disputing your choice - it's what I would have if it weren't for the Xcal2. Enjoy - it's all good.
Cheers
Bubba
Old Oct 12, 2006 | 02:29 AM
RoyalBlues's Avatar
<----------has an 2006 and an edge but my programmer is still in beta...... I was thinking about selling and getting a superchips flashpaq. What's the x2? Is the 2006 alright with edge?
Old Oct 14, 2006 | 08:52 PM
moose21's Avatar
Edge
Just a little input on the subject...I would'nt suggest any other type of tuner except for the Edge Evo.That thing does sooooooo much and the price is great for everything that it does.I mean just about any reading you want to get you can get.....its amazing.
Old Oct 15, 2006 | 12:41 PM
2001Screw4x4's Avatar
Sorry - but your dead wrong.
The Edge doesn't begin to have the fine control over A/F's required to properly & safely adjust for this, over the entire throttle position range, and at any load.
You wouldn't even know where to correct... you'd just be guessing, which is a real dumb thing to do. Not all the 2004+'s have this problem, and not all to the same degree - you only know by measuring it, and a canned tune does not factor this anomoly in out of the box. Good luck with that.
If you had bothered to search, you would not have posted such an uninformed load of BS. Good grief.
Cheers
Bubba
I was not talking about a canned tune. And, since none of our trucks are equipped with wide-band O2 sensors, we really can't tune for a specific AFR anyway. With the Edge, you can tell it to add additional fuel - maybe not to the same granular level as some of the other tuners, but they all add fuel in the same way, as an additional percentage.
Old Oct 16, 2006 | 12:02 PM
Dribone's Avatar
everyone that i've talked to and everything i've read about the edge points to no option for adjusting the A/F mix, not even adding more fuel. maybe at WOT, yes, but that doesn't help with normal idle, running and so on.
Old Oct 16, 2006 | 12:37 PM
Silverfish's Avatar
This is from Edge mechanic:
Now, I agree with you 100% that without proper equipment like a wideband AFR, tuning for fuel would generally be a pointless exercise which could end up causing severe engine damage. However, since the Mass Air Meter is controlling AFR in all situations except WOT, there really isn’t any need to pursue any fueling changes except at WOT (which is when it goes open-loop). This is precisely what we allow the user to change. Since we only allow modifications to make the vehicle richer, there really isn’t concern for engine damage. Plus, this allows for fuel enrichment in situations such as exhaust modifications where running a bit lean could be an issue. We also allow for some slight timing modifications based on current fuel quality. This can help pick up some badly needed fuel economy or allow to run a slightly lower fuel quality without risk of detonation.
Here is the link:
https://www.f150online.com/forums/sh...31#post1926131
