XCAL 2 Installed & Unbelievable
Old Sep 28, 2005 | 01:10 AM
zombiemachine's Avatar
Originally Posted by ONELOWF
The huge tires you guys want will effectively raise your gearing ( lower # ), and make your trucks slower off the line.
I switched to 410's from stock 355's, and it is like night and day off the line,and helps overall drivability. With my modest power output I can smoke em pretty good.
how does that affect your rpm's (and fuel efficiency) though if you go with the 4.10 but stick with the stock tire size? doesn't it rev higher at cruising speeds or is that something that can be corrected with a custom tune?
i currently have the 3.55 LS but i may install a 6" lift with 33's so i am thinking about replacing the diff gears
Old Sep 28, 2005 | 08:52 AM
ONELOWF's Avatar
Hey ZOMBIE-
Sure, revs higher throughout the driving range. If you do a lot of freeway driving you need to weigh the options.
With my speedo corrected for the 410's I am running 2,200 rpm @ 70 mph
- very noticably higher revs than the 355's.
I drive mostly surface streets with 31" tires, and I only wanted better acceleration and performance.
Try searching tire size and gearing - I'm sure there are more informative posts that would be helpful.
Old Sep 28, 2005 | 08:55 AM
Jackal's Avatar
If you're going to do a true 6" lift, you're probably going to want to step up to some 35's and 4:10's at a minimum. If I had a 2WD, I'd have gone 4:10's long ago.
