Datalogging
Old Sep 16, 2005 | 03:57 PM
5.4SCREW's Avatar
Talking Datalogging
As I sit here pondering my XCAL2 gains. I am wondering how many users actually datalog (no-load and load) and send them in for the really custom/fine tuning that Mike can do? Mike, what is the percentage that require more fine tuning with the data that was sent back for your handy work? I assume that "all" require some sort of retune/custom tune, per each truck's personality. I know that I want to get all I can from this tuner. Safely of course. So I am very interested in the datalogging. Any helpful hints for logging will be greatly appreciated. Thanks for all responses........ ............. ......................
Old Sep 17, 2005 | 10:34 AM
5.4SCREW's Avatar
Smile
Hi All,
Perhaps most people do not datalog, they just use what was sent as a baseline tune from Mike for their truck. I am going to attempt it, it can only get that little bit stronger/smoother with the extra insite from Mike... Still waiting................
Old Sep 17, 2005 | 11:45 AM
RED WING NUT's Avatar
I've got an Xcal2 on order from Mike for my '04 F150. I'd like to know if I could use it to datalog my brother's 2000 Lightning? If so, maybe I could get him to buy the LM1 since I would have the Xcal2 and the laptop. Is that all I need to datalog everything, Xcal2+LM1+laptop?
Old Sep 17, 2005 | 12:44 PM
ONELOWF's Avatar
I just received and installed SC2 last week, replacing another programmer.
I think the custom tunes I received are better, and so far pretty good, I'm Happy.
But I got the SC2 for it's user functions and datalogging,too.
I am now on a holy quest to find an affordable lap top with Win XP.
Old Sep 18, 2005 | 12:33 AM
5.4SCREW's Avatar
huh..............
Old Sep 18, 2005 | 02:29 AM
lrhogfan's Avatar
I am pretty sure that you need a dyno or something to measure A/F ratios. I am just going to stick with what I had sent as a baseline tune for now.
JW
Old Sep 18, 2005 | 10:58 AM
Johngs's Avatar
JW
You dont have to be on a dyno to get the A/F numbers.
Old Sep 18, 2005 | 11:43 AM
ONELOWF's Avatar
Ya- to do a/f you need an O2 wideband data recorder & logger.
They are not cheap, but if you are into it - cheaper than dyno sessions, and pretty convenient.
SEE - Innovative Motorsports LM- !
Old Sep 18, 2005 | 01:16 PM
lrhogfan's Avatar
I said that you need a dyno OR something to record A/F ratios.
Old Sep 18, 2005 | 01:46 PM
5.4SCREW's Avatar
I thought the A/F data came off the XCAL2 unit? Unless I misinderstood the information that was was e-mailed to me/us when I/we purchased XCAL2... Just looking for clarification...
Old Sep 18, 2005 | 04:57 PM
Former Sponsor
We NEVER said that the Calibrator 2 was going to read Air/Fuel ratios by itself - nothing in anything we have said here or anywhere else, and not in anything we have ever emailed anyone either, has ever said that.
The XCalibrator 2 will NOT record your A/F ratios by itself - period. You will need another device to do that - a wideband Air/Fuel ratio tester.
Now there are some low-cost units (like the Innovate Motorsports LM-1 unit that we carry) that CAN be connected to the XCal 2 via an analog cable and with some software setup will allow the XCalibrator 2 to act as a passthru device so that it can OUTPUT the A/F ratios being fed INTO it by an OUTBOARD A/F ratio recorder so you can then see those A/F's in your XCalibrator 2's datalog output file - and a lot of guys are doing just that, so I think some people may be misunderstanding how that really happens.
But the XCalibrator 2 cannot do wideband A/F testing all by itself - you have to have an outboard A/F recorder like at a dyno, or like using the LM-1 patched directly into the XCalibrator 2 to do that.
Old Sep 18, 2005 | 10:56 PM
5.4SCREW's Avatar
My "MISTAKE" Mike. I never said you said it would. I just never recall the paperwork saying we needed another type of unit to do so... My mistake, I will have to go over the paperwork again...
Old Sep 18, 2005 | 11:10 PM
Johngs's Avatar
Oops. So send me back to 4th grade
Old Sep 19, 2005 | 12:13 AM
ski's Avatar
ski
Registered User
I was fooling around with datalogging and was wondering, which parameters do I want to set up to record. Man it looks confusing using live link. There are a ton of things you can check to record. Mike which parameters would better help you with fine tuning. I was wondering if I was to send u some of my datalogging if it would help in fine tuning my 93 performance.
Ski
Old Sep 19, 2005 | 09:18 AM
5.4SCREW's Avatar
ah yes, it does say it right on top of the 2nd page. I quess I just went right for the juicy stuff and missed the important info. Any how looks like the datalogging will be an extra...Although at the begginning of this thread, I did ask for any tips ect... No one bit... ... Still waiting...yup still waiting............
