1714 ?
Old Sep 8, 2005 | 10:01 PM
4 da boat's Avatar
1714 ?
I just purchased a SuperChip 1714 for my 04 150 5.4.
I tow a small boat of about 2500 LB and I will never tow something over 4000 LB. Can I program my truck for the "Hi Performance" or do I HAVE to program my truck for the "Towing Perf." ? thanks
Old Sep 8, 2005 | 10:58 PM
jpdadeo's Avatar
As long as you’re within the weight limitations stated in the instruction manual you’d be OK
Old Sep 8, 2005 | 11:04 PM
4 da boat's Avatar
Thanks But is says "if you tow 4000 LB" and then it says "if you tow anything at all" someone most know this? will it be hard to tow if I go with the Hi Performance?
Old Sep 9, 2005 | 05:52 PM
4 da boat's Avatar
I guess I will try the Hi pro. and see what it will do in tow.
Old Sep 9, 2005 | 11:07 PM
Former Sponsor
Hi 4,
In the 1714 & 1745, you can tow up to a max of 4000lb on the 87 octane program - on the premium gas performance tune, it's really not designed for towing "significant" loads, that's what the towing program is for - so if you want to use premium gas and tow, then use the premium gas towing program. Otherwise you can just use it's 87 octane tune and tow that 2500 lb load.
Good luck!
Old Sep 10, 2005 | 12:55 AM
4 da boat's Avatar
Thanks Mike.. will I still get the 10% hp and the 13% torque ?
Old Sep 10, 2005 | 08:33 AM
jpdadeo's Avatar
4 da boat
You’ll still get at least that much with the tow-preferred premium fuel tune * you got the 3-valve! Check out this web page of Mike’s, it might help clarify your question
http://www.troyerperformance.com/cgi...catalogno=1714
Old Sep 13, 2005 | 03:02 PM
Former Sponsor
Hi 4,
If I understand your question correclty - No, obviously you are not going to get a 10% increase on peak HP running only 87 octane fuel - that happens only when running premium fuels.
