Question about calibration code
Old Aug 28, 2005 | 10:15 AM
Johngs's Avatar
On my truck, the code has worn off the sticker, I cant make it out at all...
Ive been thinking about getting a chip sometime in the future, but I was wondering if there is another way to get the code, since most chips require it?
Old Aug 28, 2005 | 01:07 PM
jpdadeo's Avatar
Check this page out Johngs it might help out
http://www.troyerperformance.com/cgi...&link=compcode
Old Aug 28, 2005 | 01:55 PM
Johngs's Avatar
Yeah Ive read that page, but the only thing it says about my year truck is to check the sticker on the passenger side door and not the drivers side sticker.
Doesnt help me much is the writing on the sticker is completely worn off
Old Aug 28, 2005 | 02:39 PM
jpdadeo's Avatar
very bottom of the page says
If you have any problems finding your computer code, or just want to check it to make sure, etc., please call us at 540-862-9515 & our staff will be happy to help you!
The code is going to be somewhere else too. Where, I don’t know but call Mike and he’ll be able to direct you to it.
Old Aug 28, 2005 | 02:52 PM
RED WING NUT's Avatar
There's a sticker on the plastic cover on the end of the computer (the end sticking inside the cab) that has the code on it. The computer is sticking through the firewall behind the right side of the glove box.
Old Aug 28, 2005 | 04:17 PM
Johngs's Avatar
Thanks Red Wing, I found it, except on my truck it was on the side inside the engine compartment.
Old Aug 28, 2005 | 04:23 PM
Glad I could help.
Old Aug 29, 2005 | 06:13 PM
Former Sponsor
Hi Johngs,
I don't know what you found, but yes, you can always look on the back of the PCM itself, inside the cabin, just above the passenger's kick panel - there will be a black plastic tab that holds the PCM, up against it's mounting bracket - pull that clip straight back to remove it, and then usually where that clip was covering up will be another code stocker - 3 letters followed by 1 number, 4 digits total.
If you ever have any problem with that, just give us a call & we'll help you out.
Good luck!
Old Aug 31, 2005 | 11:36 PM
raider's Avatar
you can get the code from the vin #...*I* have proved Mike T wrong with this before...get your vin # and call your local dealer..they can have it for you in mins
Old Sep 1, 2005 | 06:53 AM
erick_e's Avatar
My dealer must be really dumb then because they could only find the engine calibration code 4L613BOA.
Old Sep 1, 2005 | 07:58 AM
Johngs's Avatar
Thanks for the extra tips
Old Sep 1, 2005 | 08:42 AM
raider's Avatar
well they must be because they gave you the wrong calibration code even...there isnt a 4L613B0A calibration for a 04 F150...they are all 4F### #'s
