FlipChip Wiring - Which is which?
Old Jun 8, 2001 | 10:11 PM
Logan@Trilogy's Avatar
Post FlipChip Wiring - Which is which?
Hi all,
Have a R9 flipchip from a buddy of mine, and my question is How to identify the programs? Program #1 is labelled Stock and Program #2 is the Performance Program. Sooooooo, when Red & Black are connected, which program is that?
Thanks!!
Logan
99 White Lightning
69 Mercury Cougar
Old Jun 9, 2001 | 01:23 PM
Helloe's Avatar
Talking
Not real sure what R9 is but my Superchip FlipChip has the 87 / 92+ programs and it works like so. The HOME position or #1 is the 87 program and the #2 position is the 92+ octane program. The way to tell is on the treaded mounting casing of the switch there is a notch or
" vertical slot ". When the switch is pointed towards that slot you are in the "Home" or 87 program. Also you should make sure to shut of the truck before switching positions.
Hope this helps.
2001 5.4 S Cab Lariat
ORP / 3.55 L/S
Class 3 Tow Package
Gibson SweptSide
K&N Gen 2 FIPK
Superchip FLIP CHIP
LoJack
Stock HU w/ Profile CL440 Amp
Infinity Kappas Front/Infinity Reference Rears. Sub is under construction!
Old Jun 9, 2001 | 01:30 PM
Post
The switch is not on it. I just have the two wires, that's why I'm asking which wire combo is Program #1...
Logan
99 White Lightning
69 Mercury Cougar
Old Jun 9, 2001 | 07:06 PM
FamilyRide's Avatar
Thumbs up
Logan
I assume you and your buddy have the same computer code?
I'd call Mike Troyer to know for sure but my bet is that when that circuit is closed it's the second program.
2000 EDDIE BAUER EXPEDITION 4x2
-->Follow Me...<--
Old Jun 9, 2001 | 07:53 PM
Former Sponsor
Post
Hi Logan,
Well, the way it's originally connected to the switch, you would connect the red wire to the pole for Position 1, and connect the black wire to the middle contact. This will leave the third connection blank, which will be on the side of the switch housing marked "II", that's the one that will be left open.
If you don't have the original switch, then you'll need to find a suitable replacement 3-connector 2-position switch, and wire it as described above.
Good luck!
Mike Troyer
Performance Products, Inc.
(540) 862-9515
Email: mtroyer@compuserve.com
First National F-150 Online Rally Event Organizer
