Superchip installed - wow
Old Oct 24, 2000 | 06:36 AM
nascarkid's Avatar
Post Superchip installed - wow
Can't really check performance, we're getting LOTS of deserved rain here.
I really like how the tranny shifts now, even with the transgo kit I installed. I especially like the torque converter clutch operation - no more delays.
Truck seems to idle with more of an attitude than before, so I'm sure performance will be better.
I had the lip on the bracket, so I just removed the bracket and used my wizard to make a clean cut. I placed pcm on bracket and the superchip cleared great.
Wonder what one of these would do on one of our F-350 powerstroke ambulances?
1998 Nascar
TransGo shift kit - street
K&N air filter
Superchip
Wrenchjock daytime running lamps
www.wrenchjock.8m.com/nascar.htm
Old Oct 25, 2000 | 12:26 AM
Former Sponsor
Post
Hi NascarKid,
Glad to hear you're up and running, and that your installation went smoothly, excellent!
By the way, we have a number of those Powerstrokes running the Superchips, from UPS vans to ambulances, to you name it, just about every body they're available in, we make the Superchip for and people are using it.
In the Powerstroke diesel, the Superchip adds 50 horsepower and 100 lbs./ft. of torque, very nice gains indeed, thanks to the fact that it's turbocharged and deliberately de-tuned quite a bit by Ford. Another point is that the Powerstrokes usually pick up some nice gains in fuel mileage as well, so in ambulance applications it helps you get on the scene faster and quicker, and usually gets better fuel mileage as well.
The Powerstroke engine is actually manufactured by International, and thru the 2000 model year they made it available in power levels bone-stock all the way up to 325 hp and 675 lbs./ft. of torque, much higher than Ford offers. Ford de-tunes it to 235 hp & 500 lbs./ft. of torque for the 1999 & 2000 model year, for example. This is why we can make such large power gains without affecting the design service life of the powertrain, as even with the 50 hp & 100 lbs./ft. of torque we add, it's still below it's stock power output as supplied to other vehicle makers by International.
If your rescue squad would like to give this a try, just give us a shout and we can arrange that for you, to see if it will do what you want it to in your situation.
Have fun with your Superchip! (when it stops raining, that is )
Mike Troyer
Performance Products, Inc.
(540) 862-9515
Email: mtroyer@compuserve.com
First National F-150 Online Rally Event Organizer
Old Oct 25, 2000 | 12:47 AM
thomasjs's Avatar
Smile
WOW, what power gains, and capacity of the PowerStroke.
OK, I changed my mind, I want one, now where did that $4k go so I can get it :-)
Old Oct 25, 2000 | 10:55 PM
4ord_man's Avatar
Post
nascarkid, do you have any idea how fast your truck runs in the 1/4 mile? before the chip.. I have the same truck and i was just wondering because my friend wants to run me and his runs a 15.9 in the 1/4(at noble) his is a standard, mine is an auto..
Old Oct 26, 2000 | 11:51 AM
nascarkid's Avatar
Post
4ord_man.
Hope I'm doing this reply correctly.
I don't know about the time......YET. Only had the truck for about a month now. I know it *rocked* pretty good before the chip. I know I really like the tranny operation after the chip - it's awesome! I would recommend the chip just for the tranny operation. When the rain stops here, I'll get a chance to check the performance out.
The supervisors at work have an Expedition 4.6. I drove it and been with them when they are running - hot. Before the chip mine would could have *waxed* them.
If you don't have one in yours it's worth the $$ and time to install it.
1998 Nascar
K&N air filter
Superchip
Old Oct 26, 2000 | 02:32 PM
4ord_man's Avatar
Post
Thanks, also one more thing. how much did it cost to get the shift kit installed?(Im not about to try it my self, i'll break something)..
Old Oct 27, 2000 | 01:04 PM
Former Sponsor
Post
Just to give you a rough idea, it usually takes about 1 to 1.5 hours of labor to install most shift kits, so you may be able to use that time figure if you know your local labor rates to determine your cost of installation.
Good luck!
Mike Troyer
(540) 862-9515
Old Oct 27, 2000 | 01:17 PM
jackhel's Avatar
Post
Trust me if your not mechanically inclined or not good with tools don't do it. I had about a nervous breakdown installing mine. One of the valve springs shot across the garage. Thanks to a good magnet and spotlight, I found it. But with the Superchip plus the TransGo, she really shifts good, sometimes a little too hard. That's what I asked for though.
98 Nascar Edition
Homepage (Needs Updating)
Powerdyne Supercharger w/9psi, Superchip, Autometer Boost Gauge and Pod, K&N Filter, TransGo Performance Shift Kit, 295/65-16 Eagle GTII Tires, Flowmaster 40 series exhaust, Taylor 8mm wires And Bosch Plantinum Spark Plugs, TPS Mod, Gutted MAF, 4.10 Rear End Gears, XTRA Bright Halogen Lights, Amsoil Series 2000 Synthetic 0w-30 Motor Oil, Tinted Windows, Belltech 2 inch rear drop, G-Tech Pro Series II, Bedliner, 100w driving lights, Aftermarket stereo stuff w/ custom bandpass box, Cobra 75WXST CB Radio, Little Wilson Antenna, and some other stuff I can’t remember
[This message has been edited by jackhel (edited 10-27-2000).]
Old Oct 27, 2000 | 01:55 PM
nascarkid's Avatar
Smile
4ord_man
Sorry about the delay. I installed mine myself, but I've had lots of tranny experience from working at Ford dealerships before coming to the ambulance service.
You're wise to admit any limitations. I've seen guys who won't and end up destroying parts.
Mike is correct on the labor time.
jackhel. Over the period of time, I've had those springs fly, valves drop out unexpectedly and check ***** roll out from no where land.
1998 Nascar
K&N air filter
Superchip
Old Oct 27, 2000 | 02:20 PM
Former Sponsor
Post
Hi 4ord man,
Jackhel & nascartkid have made some *very* valid points about this, and I would agree.
One thing I would point out is that with most Trangso shift kits, they are available with an excellent video that gives most people the ability to get it done themselves, but you can still always run into issues, so if you're not certain about doing it yourself, you're by far better off to let a "pro" do the installation.
Like the others said, you're a wise man to let someone else handle this installation if you're not comfortable with it.
Mike Troyer
(540) 862-9515
Old Oct 29, 2000 | 01:22 AM
4ord_man's Avatar
Cool
Thanks for the info, As soon as i get some extra money i'll take it to the shop it let them handle it>
Old Oct 29, 2000 | 08:12 PM
Former Sponsor
Post
OK, & good luck!
Mike Troyer
(540) 862-9515
